Adaptive Kalman Filter for Actuator Fault Diagnosis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
An adaptive Kalman filter is proposed in this paper for actuator fault diagnosis in discrete time stochastic time varying systems. By modeling actuator faults as parameter changes, fault diagnosis is performed through joint state-parameter estimation in the considered stochastic framework. Under the classical uniform complete observability-controllability conditions and a persistent excitation condition, the exponential stability of the proposed adaptive Kalman filter is rigorously analyzed. The minimum variance property of the combined state and parameter estimation errors is also demonstrated. Numerical examples are presented to illustrate the performance of the proposed algorithm.
Automatique
adKF.pdf (300.81 Ko) Télécharger le fichier
hal-01635108 , version 1 (14-11-2017)
  • HAL Id : hal-01635108 , version 1
Qinghua Zhang. Adaptive Kalman Filter for Actuator Fault Diagnosis. IFAC 2017 - 20th World Congress of the International Federation of Automatic Control, Jul 2017, Toulouse, France. pp.1-6. ⟨hal-01635108⟩
209 Consultations
347 Téléchargements
