A Survey of Several Finite Difference Methods for Systems of Nonlinear Hyperbolic Conservation Laws
Abstract : The finite difference methods of Godunov, Hyman, Lax and Wendroff (two-step), MacCormack, Rusanov, the upwind scheme, the hybrid scheme of Harten and Zwas, the antidiffusion method of Boris and Book, the artificial compression method of Harten, and Glimm's method, a random choice method, are discussed. The methods are used to integrate the one-dimensional Eulerian form of the equations of gas dynamics in Cartesian coordinates for an inviscid, nonheat-conducting fluid. The test problem was a typical shock tube problem. The results are compared and demonstrate that Glimm's method has several advantages.
Liste complète des métadonnées
Littérature citée [19 références]  Voir  Masquer  Télécharger
https://hal.archives-ouvertes.fr/hal-01635155
Contributeur : Anders Thorin <>
Soumis le : mardi 14 novembre 2017 - 18:12:46
Dernière modification le : mardi 6 mars 2018 - 18:55:12
Document(s) archivé(s) le : jeudi 15 février 2018 - 16:20:53
Fichier
GAS.pdf
Fichiers produits par l'(les) auteur(s)
Collections
Citation
Gary Sod. A Survey of Several Finite Difference Methods for Systems of Nonlinear Hyperbolic Conservation Laws. Journal of Computational Physics, Elsevier, 1978, 27 (1), pp.1-31. 〈10.1016/0021-9991(78)90023-2〉. 〈hal-01635155〉
Métriques
Consultations de la notice
88
Téléchargements de fichiers
668
