Flux-corrected transport. I. SHASTA, a fluid transport algorithm that works, Journal of Computational Physics, vol.11, issue.1, p.38, 1973. ,
DOI : 10.1016/0021-9991(73)90147-2
Random choice solution of hyperbolic systems, Journal of Computational Physics, vol.22, issue.4, p.517, 1976. ,
DOI : 10.1016/0021-9991(76)90047-4
URL : http://www.math.berkeley.edu/%7Echorin/C76.pdf
Random choice methods with applications to reacting gas flow, Journal of Computational Physics, vol.25, issue.3, p.253, 1977. ,
DOI : 10.1016/0021-9991(77)90101-2
A computational scheme for two-dimensional non stationary problems of gas dynamics and calculation of the flow from a shock wave approaching a stationary state, USSR Computational Mathematics and Mathematical Physics, vol.1, issue.4, p.1187, 1962. ,
DOI : 10.1016/0041-5553(62)90039-3
Solutions in the large for nonlinear hyperbolic systems of equations, Communications on Pure and Applied Mathematics, vol.12, issue.4, p.697, 1965. ,
DOI : 10.1002/cpa.3160180408
The Method of Artificial Compression, 1974. ,
The artificial compression method for computation of shocks and contact discontinuities. I. Single conservation laws, Communications on Pure and Applied Mathematics, vol.21, issue.5, p.611, 1977. ,
DOI : 10.1002/cpa.3160300506
The artificial compression method for shocks and contact discontinuities. Ill. Self-adjusting hybrid schemes ,
DOI : 10.2172/4300016
A generalized version of Glimm's method ,
On robust and accurate methods for the calculation of compressible fluid flows, I ,
A detached shock calculation by second-order finite differences, Journal of Computational Physics, vol.2, issue.2, p.154, 1967. ,
DOI : 10.1016/0021-9991(67)90032-0
Weak solutions of nonlinear hyperbolic equations and their numerical computation, Communications on Pure and Applied Mathematics, vol.24, issue.1, p.159, 1954. ,
DOI : 10.1002/cpa.3160070112
Hyperbolic systems of conservation laws II, Communications on Pure and Applied Mathematics, vol.3, issue.4, p.537, 1957. ,
DOI : 10.4153/CJM-1949-007-x
Stabilization of difference schemes for the equations of inviscid compressible flow by artificial diffusion, Journal of Computational Physics, vol.3, issue.4, p.473, 1969. ,
DOI : 10.1016/0021-9991(69)90056-4
A Survey of Difference Methods for Non-Steady Fluid Dynamics, National Center for Atmospheric Research, 1962. ,
Difference Methods for Initial-Value Problems, 1967. ,
The Computer Implementation of Glimm's Method, 1976. ,
A numerical model of unsteady combustion phenomena ,
Numerical Analysis with Application to Fluid Dynamics, Courant Institute Lecture Notes ,
