Randomized Abortable Mutual Exclusion with Constant Amortized RMR Complexity on the CC Model
We present an abortable mutual exclusion algorithm for the cache-coherent (CC) model with atomic registers and CAS objects. The algorithm has constant expected amortized RMR complexity in the oblivious adversary model and is deterministically deadlock-free. This is the first abortable mutual exclusion algorithm that achieves o(log n/log log n) RMR complexity.
Informatique [cs]
