Upper Bounds for Boundless Tagging with Bounded Objects, Proc. of 30th DISC, pp.442-457, 2016. ,
DOI : 10.1145/378580.378611
Sub-logarithmic Test-and-Set against a Weak Adversary, Proc. of 25th DISC, pp.97-109, 2011. ,
DOI : 10.1007/s004460200071
URL : http://www.cs.yale.edu/homes/aspnes/papers/disc2011-proceedings-oblivious-tas.pdf
Adaptive Mutual Exclusion with Local Spinning, Proc. of 14th DISC, pp.29-43, 2000. ,
DOI : 10.1007/3-540-40026-5_2
An improved lower bound for the time complexity of mutual exclusion, Distributed Computing, vol.15, issue.4, pp.221-253, 2002. ,
DOI : 10.1007/s00446-002-0084-2
Shared-memory mutual exclusion: major research trends since 1986, Distributed Computing, vol.16, issue.2-3, pp.75-110, 2003. ,
DOI : 10.1007/s00446-003-0088-6
The performance of spin lock alternatives for shared-money multiprocessors, IEEE Transactions on Parallel and Distributed Systems, vol.1, issue.1, pp.6-16, 1990. ,
DOI : 10.1109/71.80120
Faster randomized consensus with an oblivious adversary, Proc. of 31st PODC, pp.1-8, 2012. ,
DOI : 10.1007/s00446-013-0195-y
An O(1)-barriers optimal RMRs mutual exclusion algorithm, Proceedings of the 2013 ACM symposium on Principles of distributed computing, PODC '13, pp.220-229, 2013. ,
DOI : 10.1145/2484239.2484255
Tight RMR Lower Bounds for Mutual Exclusion and Other Problems, Proc. of 40th ACM STOC, pp.217-226, 2008. ,
DOI : 10.1145/1374376.1374410
URL : http://pages.cpsc.ucalgary.ca/~woelfel/paper/MutEX-Lower-Bound/paper.pdf
Trading Fences with RMRs and Separating Memory Models, Proceedings of the 2015 ACM Symposium on Principles of Distributed Computing, PODC '15, pp.173-182, 2015. ,
DOI : 10.1007/BF01784242
The Price of being Adaptive, Proceedings of the 2015 ACM Symposium on Principles of Distributed Computing, PODC '15, pp.183-192, 2015. ,
Mutual Exclusion with O(log^2 Log n) Amortized Work, 2011 IEEE 52nd Annual Symposium on Foundations of Computer Science, pp.728-737, 2011. ,
DOI : 10.1109/FOCS.2011.84
Parallel Computer Architecture: A Hardware/Software Approach, 1998. ,
Closing the complexity gap between FCFS mutual exclusion and mutual exclusion, Distributed Computing, vol.2, issue.3, pp.87-111, 2010. ,
DOI : 10.1007/s00446-010-0096-2
Brief Announcement: Local-Spin Algorithms for Abortable Mutual Exclusion and Related Problems, Proc. of 22nd DISC, pp.512-513, 2008. ,
DOI : 10.1007/978-3-540-87779-0_41
Are Shared Objects Composable under an Oblivious Adversary?, Proceedings of the 2016 ACM Symposium on Principles of Distributed Computing, PODC '16, pp.335-344, 2016. ,
DOI : 10.1109/ICDCS.2003.1203503
Solution of a problem in concurrent programming control, Communications of the ACM, vol.8, issue.9, p.569, 1965. ,
DOI : 10.1145/365559.365617
On the time and space complexity of randomized test-and-set, Proceedings of the 2012 ACM symposium on Principles of distributed computing, PODC '12, pp.19-28, 2012. ,
DOI : 10.1145/2332432.2332436
URL : https://hal.archives-ouvertes.fr/hal-00722947
A tight RMR lower bound for randomized mutual exclusion, Proceedings of the 44th symposium on Theory of Computing, STOC '12, pp.983-1002, 2012. ,
DOI : 10.1145/2213977.2214066
URL : https://hal.archives-ouvertes.fr/hal-00722940
Randomized Mutual Exclusion with Constant Amortized RMR Complexity on the DSM, 2014 IEEE 55th Annual Symposium on Foundations of Computer Science, pp.504-513, 2014. ,
DOI : 10.1109/FOCS.2014.60
URL : https://hal.archives-ouvertes.fr/hal-01097144
RMR-efficient implementations of comparison primitives using read and write operations, Distributed Computing, vol.9, issue.1, pp.109-162, 2012. ,
Linearizable implementations do not suffice for randomized distributed computation, Proceedings of the 43rd annual ACM symposium on Theory of computing, STOC '11, pp.373-382, 2011. ,
DOI : 10.1145/1993636.1993687
URL : http://arxiv.org/pdf/1103.4690.pdf
Adaptive randomized mutual exclusion in sub-logarithmic expected time, Proceeding of the 29th ACM SIGACT-SIGOPS symposium on Principles of distributed computing, PODC '10, pp.141-150, 2010. ,
DOI : 10.1145/1835698.1835737
Randomized mutual exclusion with sub-logarithmic RMR-complexity, Distributed Computing, vol.9, issue.1, pp.3-19, 2011. ,
URL : http://www.cs.bgu.ac.il/%7Ehendlerd/papers/RandomizedMutex.pdf
The art of multiprocessor programming, Proceedings of the twenty-fifth annual ACM symposium on Principles of distributed computing , PODC '06, 2008. ,
DOI : 10.1145/1146381.1146382
Adaptive and efficient abortable mutual exclusion, Proceedings of the twenty-second annual symposium on Principles of distributed computing , PODC '03, pp.295-304, 2003. ,
DOI : 10.1145/872035.872079
Read/Write Based Fast-Path Transformation for FCFS Mutual Exclusion, Proc. of 31st SOFSEM, pp.209-218, 2005. ,
DOI : 10.1007/978-3-540-30577-4_24
A Time Complexity Bound for Adaptive Mutual Exclusion, Proc. of 15th DISC, pp.1-15, 2001. ,
DOI : 10.1007/3-540-45414-4_1
URL : http://cs.unc.edu/~anderson/papers/disc01.ps
Nonatomic mutual exclusion with local spinning, Distributed Computing, vol.9, issue.1, pp.19-61, 2006. ,
DOI : 10.1109/2.55501
URL : http://cs.unc.edu/~anderson/papers/podc02.ps
Transformations of Mutual Exclusion Algorithms from the Cache-Coherent Model to the Distributed Shared Memory Model, Proc. of 25th ICDCS, pp.261-270, 2005. ,
Fast Local-Spin Abortable Mutual Exclusion with Bounded Space, Proc. of 14th OPODIS, pp.364-379, 2010. ,
DOI : 10.1145/224964.224988
Algorithms for scalable synchronization on shared-memory multiprocessors, ACM Trans. Comput. Syst, vol.9, issue.1, pp.21-65, 1991. ,
RMR-Efficient Randomized Abortable Mutual Exclusion, Proc. of 26th DISC, pp.267-281, 2012. ,
DOI : 10.1007/978-3-642-33651-5_19
URL : http://arxiv.org/pdf/1208.1723.pdf
Algorithms for Mutual Exclusion, 1986. ,
URL : https://hal.archives-ouvertes.fr/inria-00075216
Non-blocking timeout in scalable queue-based spin locks, Proc. of 21st PODC, pp.31-40, 2002. ,
A fast, scalable mutual exclusion algorithm, Distributed Computing, vol.9, issue.1, pp.51-60, 1995. ,
URL : http://www.cs.unc.edu/~anderson/papers/dc95.ps
