On the Length of Medial-Switch-Mix Derivations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Switch and medial are two inference rules that play a central role in many deep inference proof systems. In specific proof systems, the mix rule may also be present. In this paper we show that the maximal length of a derivation using only the inference rules for switch, medial, and mix, modulo associativity and commutativity of the two binary con-nectives involved, is quadratic in the size of the formula at the conclusion of the derivation. This shows, at the same time, the termination of the rewrite system.
sm-length.pdf (279 Ko) Télécharger le fichier
hal-01635933 , version 1 (15-11-2017)
  • HAL Id : hal-01635933 , version 1
Paola Bruscoli, Lutz Strassburger. On the Length of Medial-Switch-Mix Derivations. WoLLIC 2017 - Logic, Language, Information, and Computation, Jul 2017, London, United Kingdom. ⟨hal-01635933⟩
120 Consultations
76 Téléchargements
