Design and implementation of numerical linear algebra algorithms on fixed point dsps, EURASIP Journal on Advances in Signal Processing, 2007. ,
Reconfigurable adaptive singular value decomposition engine design for highthroughput mimo-ofdm systems Very Large Scale Integration (VLSI) Systems, IEEE Transactions on, vol.21, issue.4, pp.747-760, 2013. ,
DOI : 10.1109/tvlsi.2012.2195040
Singular value decomposition using an array of CORDIC processors, Signal Processing, vol.102, pp.163-170, 2014. ,
DOI : 10.1016/j.sigpro.2014.03.022
Fixed-point hestenes svd algorithm for computing eigen faces ,
Design and Performance Analysis of Fixed-point Jacobi SVD Algorithm on Reconfigurable System, IERI Procedia, pp.21-27, 2014. ,
DOI : 10.1016/j.ieri.2014.08.005
Cordic and svd implementation in digital hardware, Mixed Design of Integrated Circuits and Systems (MIXDES), 2010 Proceedings of the 17th International Conference, pp.237-242, 2010. ,
FPGA design of a truncated SVD based receiver for the detection of SEFDM signals, 2011 IEEE 22nd International Symposium on Personal, Indoor and Mobile Radio Communications, pp.2085-2090, 2011. ,
DOI : 10.1109/PIMRC.2011.6139882
Singular Value Decomposition Hardware for MIMO: State of the Art and Custom Design, 2010 International Conference on Reconfigurable Computing and FPGAs, pp.400-405, 2010. ,
DOI : 10.1109/ReConFig.2010.62
Application-specific instruction set processor for soc implementation of modern signal processing algorithms Circuits and Systems I: Regular Papers, IEEE Transactions on, vol.52, issue.4, pp.755-765, 2005. ,
Automated fixed-point data-type optimization tool for signal processing and communication systems, Proceedings of the 41st annual conference on Design automation , DAC '04, pp.478-483, 2004. ,
DOI : 10.1145/996566.996700
Fixed-point optimization utility for c and c++ based digital signal processing programs, Circuits and Systems II: Analog and Digital Signal Processing, pp.1455-1464, 1998. ,
Autoscaler for c: An optimizing floating-point to integer c program converter for fixed-point digital signal processors Circuits and Systems II: Analog and Digital Signal Processing, IEEE Transactions on, vol.47, issue.9, pp.840-848, 2000. ,
Accuracy-guaranteed bit-width optimization Computer-Aided Design of Integrated Circuits and Systems, IEEE Transactions on, vol.25, issue.10, 1990. ,
DOI : 10.1109/tcad.2006.873887
URL : http://spiral.imperial.ac.uk/bitstream/10044/1/788/1/Accuracy-Guaranteed%20bit-width.pdf
Improved intervalbased characterization of fixed-point lti systems with feedback loops Computer-Aided Design of Integrated Circuits and Systems, IEEE Transactions on, vol.26, issue.11, pp.1923-1933, 2007. ,
Bit-width allocation for hardware accelerators for scientific computing using sat-modulo theory Computer-Aided Design of Integrated Circuits and Systems, IEEE Transactions on, vol.29, issue.3, pp.405-413, 2010. ,
Enhanced precision analysis for accuracy-aware bit-width optimization using affine arithmetic Computer-Aided Design of Integrated Circuits and Systems, IEEE Transactions on, vol.32, issue.12, pp.1853-1865, 2013. ,
Development of numerical linear algebra algorithms in dynamic fixed-point format: a case study of Lanczos tridiagonalization, International Journal of Circuit Theory and Applications, vol.2, issue.4, pp.1222-1262, 2016. ,
DOI : 10.1109/ISCAS.2012.6272100
Dynamic-range estimation Computer-Aided Design of Integrated Circuits and Systems, IEEE Transactions on, vol.25, issue.9, pp.1618-1636, 2006. ,
Numerical Data Representations for FPGA-Based Scientific Computing, IEEE Design & Test of Computers, vol.28, issue.4, pp.8-17, 2011. ,
DOI : 10.1109/MDT.2011.48
A stochastic approach for the range evaluation, 2012. ,
URL : https://hal.archives-ouvertes.fr/tel-00768862
Determining appropriate precisions for signals in fixed-point IIR filters, Proceedings of the 40th conference on Design automation , DAC '03, pp.656-661, 2003. ,
DOI : 10.1145/775832.775998
A zonotopic framework for functional abstractions, Formal Methods in System Design, vol.2, issue.1???4, pp.302-360, 2015. ,
DOI : 10.1007/11513988_21
URL : http://arxiv.org/pdf/0910.1763
Integer word-length optimization for fixed-point systems, 2014 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.8321-8325, 2014. ,
DOI : 10.1109/ICASSP.2014.6855224
Automated range and precision bitwidth allocation for iterative computations, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.9, issue.30, pp.1265-1278, 2011. ,
DOI : 10.1109/tcad.2011.2152840
On the fixed-point accuracy analysis and optimization of polynomial specifications Computer-Aided Design of Integrated Circuits and Systems, IEEE Transactions on, vol.32, issue.6, pp.831-844, 2013. ,
The Promise of Reconfigurable Computing for Hyperspectral Imaging Onboard Systems: A Review and Trends, Adaptive Hardware and Systems (AHS), 2012 NASA/ESA Conference on, pp.698-722, 2012. ,
DOI : 10.1109/JPROC.2012.2231391
Adaptive hyperspectral image compression using the KLT and integer KLT algorithms, 2014 NASA/ESA Conference on Adaptive Hardware and Systems (AHS), pp.112-119, 2014. ,
DOI : 10.1109/AHS.2014.6880166
Data handling in hyperspectral image analysis, Chemometrics and Intelligent Laboratory Systems, vol.108, issue.1, pp.13-22, 2011. ,
DOI : 10.1016/j.chemolab.2011.04.001
Numerical linear algebra and applications. Siam, 2010. ,
DOI : 10.1137/1.9780898717655
Matrix computations, 2012. ,
Comparative Evaluation of Symmetric SVD Algorithms for Real-Time Face and Eye Tracking, Matrix information geometry, pp.323-340, 2013. ,
DOI : 10.1007/978-3-642-30232-9_13
Jacobi???s Method is More Accurate than QR, SIAM Journal on Matrix Analysis and Applications, vol.13, issue.4, pp.1204-1245, 1992. ,
DOI : 10.1137/0613074
Hardware acceleration of the integer karhunenlò eve transform algorithm for satellite image compression, Geoscience and Remote Sensing Symposium (IGARSS), pp.4062-4065, 2012. ,
A novel fpgabased architecture for the estimation of the virtual dimensionality in remotely sensed hyperspectral images, Journal of Real-Time Image Processing, pp.1-12 ,
An overflow-free fixed-point singular value decomposition algorithm for dimensionality reduction of hyperspectral images, DecompositionAlgorith [37], 2015. ,
A collection of hyperspectral images for imaging systems research, Digital Photography IX, pp.86-600, 2013. ,
DOI : 10.1117/12.2007097
Eetesthe enmap end-to-end simulation tool Selected Topics in Applied Earth Observations and Remote Sensing, Higham, Accuracy and stability of numerical algorithms. Siam, pp.522-530, 2002. ,
DOI : 10.1109/jstars.2012.2188994
Interval analysis, 1966. ,
Analytical approach for numerical accuracy estimation of fixed-point systems based on smooth operations Circuits and Systems I: Regular Papers, IEEE Transactions on, vol.59, issue.10, pp.2326-2339, 2012. ,
Mean squared error: Love it or leave it? A new look at Signal Fidelity Measures, IEEE Signal Processing Magazine, vol.26, issue.1, pp.98-117, 2009. ,
DOI : 10.1109/MSP.2008.930649
High-level synthesis with vivado hls, 2013. ,
Ieee std. 1666?2005 open systemc language reference manual, 2005. ,
