Microservices: How To Make Your Application Scale - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The microservice architecture is a style inspired by service-oriented computing that has recently started gaining popularity and that promises to change the way in which software is perceived, conceived and designed. In this paper, we describe the main features of microservices and highlight how these features improve scalability.
microservices-make-application.pdf (525.41 Ko) Télécharger le fichier
hal-01636132 , version 1 (16-11-2017)
  • HAL Id : hal-01636132 , version 1
Nicola Dragoni, Ivan Lanese, Stephan Thordal Larsen, Manuel Mazzara, Ruslan Mustafin, et al.. Microservices: How To Make Your Application Scale. A.P. Ershov Informatics Conference (the PSI Conference Series, 11th edition), Jun 2017, Moscow, Russia. ⟨hal-01636132⟩
183 Consultations
3038 Téléchargements
