Adversarial autoencoders for novelty detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2017
Valentin Leveau
  • Fonction : Auteur
  • PersonId : 961045
Alexis Joly
In this paper, we address the problem of novelty detection, i.e recognizing at test time if a data item comes from the training data distribution or not. We focus on Adversarial autoencoders (AAE) that have the advantage to explicitly control the distribution of the known data in the feature space. We show that when they are trained in a (semi-)supervised way, they provide consistent novelty detection improvements compared to a classical autoencoder. We further improve their performance by introducing an explicit rejection class in the prior distribution coupled with random input images to the autoencoder.
valentin.pdf (3.41 Mo) Télécharger le fichier
hal-01636617 , version 1 (16-11-2017)
  • HAL Id : hal-01636617 , version 1
Valentin Leveau, Alexis Joly. Adversarial autoencoders for novelty detection. [Research Report] Inria - Sophia Antipolis. 2017. ⟨hal-01636617⟩
564 Consultations
942 Téléchargements
