High-dimensional approximate r-nets
The construction of r-nets offers a powerful tool in computational and metric geometry. We focus on high-dimensional spaces and present a new randomized algorithm which efficiently computes approximate $r$-nets with respect to Euclidean distance. For any fixed \epsilon>0, the approximation factor is 1+\epsilon and the complexity is polynomial in the dimension and subquadratic in the number of points. The algorithm succeeds with high probability. More specifically, the best previously known LSH-based construction of Eppstein et al. [EHS15] is improved in terms of complexity by reducing the dependence on \epsilon, provided that $\epsilon$ is sufficiently small. Our method does not require LSH but, instead, follows Valiant's [Val15] approach in designing a sequence of reductions of our problem to other problems in different spaces, under Euclidean distance or inner product, for which r-nets are computed efficiently and the error can be controlled. Our result immediately implies efficient solutions to a number of geometric problems in high dimension, such as finding the (1+\epsilon)-approximate k-th nearest neighbor distance in time subquadratic in the size of the input.
