Will e-Participation Bring Critical Citizens Back In? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Joachim Åström
  • Fonction : Auteur
  • PersonId : 1004256
Martin Karlsson
  • Fonction : Auteur
  • PersonId : 1004259
This paper sets out to critically examine the mobilizing potential of e-participation. The extent to which citizens beyond the usual suspects are engaged is studied by way of survey data from two novel e-participation case studies: one Swedish, one Finnish. Besides from the traditional socio-demographic variables, the analyses highlights cultural attitudes and ask: Do e-participation processes succeed in mobilizing citizens dissatisfied with the way democracy works? Can e-participation bring critical citizens back in? Certainly, the empirical analysis indicates critical citizens are clearly overrepresented in these two cases.
430552_1_En_7_Chapter.pdf (88.18 Ko) Télécharger le fichier
hal-01637235 , version 1 (17-11-2017)
Paternité
Joachim Åström, Martin Karlsson. Will e-Participation Bring Critical Citizens Back In?. 8th International Conference on Electronic Participation (ePart), Sep 2016, Guimarães, Portugal. pp.83-93, ⟨10.1007/978-3-319-45074-2_7⟩. ⟨hal-01637235⟩
71 Consultations
133 Téléchargements
