Methods of Synthesis of Controlled Random Tests - Archive ouverte HAL Access content directly
Conference Papers Year : 2016
(1) , (1)
1
Ireneusz Mrozek
  • Function : Author
  • PersonId : 1023005
Vyacheslav Yarmolik
  • Function : Author
  • PersonId : 1023006
Controlled random tests, methods of their generation, main criteria used for their synthesis, such as the Hamming distance and the Euclidean distance, as well as their application to the testing of both hardware and software systems are discussed. Available evidences suggest that high computational complexity is one of the main drawbacks of these methods. Therefore we propose a technique to overcome this problem. A method for synthesizing multiple controlled random tests based on the use of the initial random test and addition operation has been proposed. The resulting multiple tests can be interpreted as a single controlled random test. The complexity of its construction is significantly lower than the complexity of the construction of classical random tests. Examples of generated tests as well as estimates of their effectiveness compared to other solutions have been presented in experimental studies.
419526_1_En_38_Chapter.pdf (131.8 Ko) Télécharger le fichier
Dates and versions
hal-01637455 , version 1 (17-11-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Ireneusz Mrozek, Vyacheslav Yarmolik. Methods of Synthesis of Controlled Random Tests. 15th IFIP International Conference on Computer Information Systems and Industrial Management (CISIM), Sep 2016, Vilnius, Lithuania. pp.429-440, ⟨10.1007/978-3-319-45378-1_38⟩. ⟨hal-01637455⟩
88 View
59 Download
Share
