Keel datamining software tool: Data set repository, integration of algorithms and experimental analysis framework. Multiple-Valued Logic and Soft Computing, pp.255-287, 2011. ,
Safe-Level-SMOTE: Safe-Level-Synthetic Minority Over-Sampling TEchnique for Handling the Class Imbalanced Problem, Proceedings of Advances in Knowledge Discovery and Data Mining: 13th Pacific-Asia Conference ,
DOI : 10.1007/978-3-540-24694-7_32
URL : http://sci2s.ugr.es/keel/pdf/algorithm/congreso/2009-Bunkhumpornpat-LNCS.pdf
Smote: Synthetic minority over-sampling technique, Journal of Artificial Intelligence Research, vol.16, pp.321-357, 2002. ,
Editorial, SIGKDD Explorations, pp.1-6, 2004. ,
DOI : 10.1145/1007730.1007733
Nearest neighbor pattern classification, IEEE Transactions on Information Theory, vol.13, issue.1, pp.21-27, 1967. ,
DOI : 10.1109/TIT.1967.1053964
URL : http://ssg.mit.edu/cal/abs/2000_spring/np_dens/classification/cover67.pdf
The WEKA data mining software, ACM SIGKDD Explorations Newsletter, vol.11, issue.1, pp.10-18, 2009. ,
DOI : 10.1145/1656274.1656278
The elements of statistical learning: data mining, inference and prediction, 2009. ,
Learning from imbalanced data, IEEE Transactions on Knowledge and Data Engineering, vol.21, issue.9, pp.1263-1284, 2009. ,
ROC Curves for Continuous Data, CRC, vol.111, 2009. ,
DOI : 10.1201/9781439800225
URL : http://www.crcnetbase.com/doi/pdfplus/10.1201/9781439800225.fmatt
Selective Pre-processing of Imbalanced Data for Improving Classification Performance, Proceedings of Data Warehousing and Knowledge Discovery: 10th International Conference, 2008. ,
DOI : 10.1007/978-3-540-85836-2_27
Dealing with imbalanced data: undersampling, oversampling and proper cross-validation, http://www.marcoaltini.com/blog/dealing-with- imbalanced-data-undersampling-oversampling-and-proper-cross-validation ,
