Conference papers
Skull Stripping for MRI Images Using Morphological Operators
Abstract : One of the most common MRI (Magnetic Resonance Imaging) use is a brain visualisation. Brain anatomy is highly complicated therefore it might be difficult to extract only these structures which have diagnostic value. In a consequence it is so necessary to develop and apply most efficient brain’s segmentation algorithms. One of the first steps in case of neurological MRI analysis is skull stripping. It involves removing extra-meningeal tissue from the head image, therefore it is essential to find the best method to determine the brain and skull boundaries. In T1-weighted images, cerebrospinal fluid (CSF) space and skull are dark, that is why the edges between the brain and the skull are well-marked but even strong edges might be unsettled because of finite resolution during MRI acquisition or the presence of other anatomical partial structures within the brain (connections between the brain and optic nerves or brainstem). There are many ways to perform this operation, none of them is not so great as to constitute a standard proceedings. In many cases, there are limitations associated with the development environment, license and images input that hinder skull stripping without specialised software. Proposed method is free of these constraints. It is based on application of morphological operations and image filtration to enhance the result of the edge detection and to provide better tissues separation. The efficiency was compared with other methods, common in commercial use, and the results of this comparison was presented in this paper.
Complete list of metadata
Cited literature [9 references]  Display  Hide  Download
https://hal.inria.fr/hal-01637463
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Friday, November 17, 2017 - 3:43:34 PM
Last modification on : Thursday, October 4, 2018 - 10:12:02 PM
Long-term archiving on: : Sunday, February 18, 2018 - 3:39:44 PM
File
419526_1_En_16_Chapter.pdf
Identifiers
Collections
Citation
Joanna Swiebocka-Wiek. Skull Stripping for MRI Images Using Morphological Operators. 15th IFIP International Conference on Computer Information Systems and Industrial Management (CISIM), Sep 2016, Vilnius, Lithuania. pp.172-182, ⟨10.1007/978-3-319-45378-1_16⟩. ⟨hal-01637463⟩
Share
Metrics
Record views
143
Files downloads
783
