A Fault-Tolerant Authenticated Key-Conference Agreement Protocol with Forward Secrecy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In conference channels, users communicate with each other using a conference key that is used to encrypt messages. There are two basic approaches in which the key can be established. In the first one, a central server is used (with a chairman role). The server generates the key and distributes it to participants. The second approach is that all participants compute a key without a chairman. In this paper, we introduce a special type of group authentication using secret sharing, which provides an efficient way to authenticate multiple users belonging to the same group without the chairman. Our proposed protocol is a many-to-many type of authentication. Unlike most user authentication protocols that authenticate a single user each time, our proposed protocol authenticates all users of a group at once.
419526_1_En_56_Chapter.pdf (558.98 Ko) Télécharger le fichier
hal-01637470 , version 1 (17-11-2017)
Paternité
Tomasz Hyla, Jerzy Pejaś. A Fault-Tolerant Authenticated Key-Conference Agreement Protocol with Forward Secrecy. 15th IFIP International Conference on Computer Information Systems and Industrial Management (CISIM), Sep 2016, Vilnius, Lithuania. pp.647-660, ⟨10.1007/978-3-319-45378-1_56⟩. ⟨hal-01637470⟩
195 Consultations
66 Téléchargements
