Performance Evaluation of Probabilistic Time-Dependent Travel Time Computation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Martin Golasowski
  • Fonction : Auteur
  • PersonId : 994912
Radek Tomis
  • Fonction : Auteur
  • PersonId : 999161
Jan Martinovič
  • Fonction : Auteur
  • PersonId : 994854
Lukáš Rapant
  • Fonction : Auteur
  • PersonId : 999158
Computational performance of route planning algorithms has become increasingly important in recent real navigation applications with many simultaneous route requests. Navigation applications should recommend routes as quickly as possible and preferably with some added value. This paper presents a performance evaluation of the main part of probabilistic time-dependent route planning algorithm. The main part of the algorithm computes the full probability distribution of travel time on routes with Monte Carlo simulation. Experiments show the performance of the algorithm and suggest real possibilities of use in modern navigation applications.
419526_1_En_34_Chapter.pdf (333.02 Ko) Télécharger le fichier
hal-01637471 , version 1 (17-11-2017)
Paternité
Martin Golasowski, Radek Tomis, Jan Martinovič, Kateřina Slaninová, Lukáš Rapant. Performance Evaluation of Probabilistic Time-Dependent Travel Time Computation. 15th IFIP International Conference on Computer Information Systems and Industrial Management (CISIM), Sep 2016, Vilnius, Lithuania. pp.377-388, ⟨10.1007/978-3-319-45378-1_34⟩. ⟨hal-01637471⟩
38 Consultations
100 Téléchargements
