Determinig embedding dimension for phase-space reconstruction using a geometrical construction, Physical Review A, issue.6, p.45, 1992. ,
Comparison of algorithms calculating optimal embedding parameters for delay time coordinates, Physica D: Nonlinear Phenomena, vol.58, issue.1-4, pp.127-137, 1992. ,
DOI : 10.1016/0167-2789(92)90104-U
Optimal delay time and embedding dimension for delay-time coordinates by analysis of the global static and local dynamical behavior of strange attractors, Physical Review A, vol.191, issue.10, pp.7073-7084, 1992. ,
DOI : 10.1017/S0022112088001491
Dynamics from multivariate time series, Physica D: Nonlinear Phenomena, vol.121, issue.1-2, pp.75-88, 1998. ,
DOI : 10.1016/S0167-2789(98)00151-1
Practical method for determining the minimum embedding dimension of a scalar time series, Physica D: Nonlinear Phenomena, vol.110, issue.1-2, pp.43-50, 1997. ,
DOI : 10.1016/S0167-2789(97)00118-8
Independent coordinates for strange attractors from mutual information, Physical Review A, vol.55, issue.2, 1986. ,
DOI : 10.1088/0031-8949/1985/T9/021
Hong-guang M. Selection of embedding dimension and delay time in phase space reconstruction, Front. Electr. Electron. Eng, vol.1, pp.111-114, 2006. ,
Quaternion Dynamic Time Warping, IEEE Transactions on Signal Processing, vol.60, issue.3, pp.1174-1183, 2012. ,
DOI : 10.1109/TSP.2011.2177832
Selection of proper time-delay in phase space reconstruction of speech signals, Signal Process, vol.15, pp.220-225, 1999. ,
Some methods for classification and analysis of multivariate observations, pp.281-297, 1967. ,
Neural network method for determining embedding dimension of a time series, Communications in Nonlinear Science and Numerical Simulation, vol.16, issue.8, pp.3294-3302, 2011. ,
DOI : 10.1016/j.cnsns.2010.10.030
MuTE: A MATLAB Toolbox to Compare Established and Novel Estimators of the Multivariate Transfer Entropy, PLoS ONE, vol.367, issue.10, p.109462, 2014. ,
DOI : 10.1371/journal.pone.0109462.t002
Clustering Methods, 2005. ,
DOI : 10.1007/0-387-25465-X_15
Reconstruction expansion as a geometry-based framework for choosing proper delay times, Physica D, vol.73, pp.82-98, 1994. ,
Detecting strange attractors in turbulence, 1981. ,
DOI : 10.1007/BF01646553
Nonuniform state-space reconstruction and coupling detection, Physical Review E, vol.82, issue.1, p.16207, 2010. ,
DOI : 10.1093/brain/awl304
