Conference papers
Process of Point Clouds Merging for Mapping of a Robot’s Working Environment
Abstract : The lidar is nowadays increasingly used in many robotic applications. Nevertheless the 3D lidars are still very expensive and their use on small robots is not economical. This article briefly introduces a construction of cheap 3D lidar for indoor usage based on the 2D laser range finder. Subsequently, this article introduces process of merging acquired point clouds. The every pair of neighboring point clouds is oriented in space to fit together in the best possible way. The result of this process is a 3D map of the robot working environment. This map can be segmented and further used for a navigation. In this way, it is also possible to map inaccessible and dangerous areas.
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/hal-01637492
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Friday, November 17, 2017 - 3:44:53 PM
Last modification on : Saturday, June 1, 2019 - 11:34:02 AM
Long-term archiving on: : Sunday, February 18, 2018 - 3:20:14 PM
File
419526_1_En_23_Chapter.pdf
Identifiers
Collections
Citation
Petr Olivka, Michal Krumnikl, Pavel Moravec, David Seidl. Process of Point Clouds Merging for Mapping of a Robot’s Working Environment. 15th IFIP International Conference on Computer Information Systems and Industrial Management (CISIM), Sep 2016, Vilnius, Lithuania. pp.251-264, ⟨10.1007/978-3-319-45378-1_23⟩. ⟨hal-01637492⟩
Share
Metrics
Record views
72
Files downloads
89
