Robust Tabu Search Algorithm for Planning Rail-Truck Intermodal Freight Transport - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper a new efficient tabu search algorithm for assigning freight to the intermodal transport connections was developed. There were also formulated properties of the problem that can be used to design robust heuristic algorithms based on the local search methods. The quality of solutions produced by the tabu search algorithm and by often recommended greedy approach were also compared.
419526_1_En_26_Chapter.pdf (221.32 Ko) Télécharger le fichier
hal-01637497 , version 1 (17-11-2017)
Paternité
Wojciech Bożejko, Radoslaw Grymin, Szymon Jagiełło, Jarosław Pempera. Robust Tabu Search Algorithm for Planning Rail-Truck Intermodal Freight Transport. 15th IFIP International Conference on Computer Information Systems and Industrial Management (CISIM), Sep 2016, Vilnius, Lithuania. pp.289-299, ⟨10.1007/978-3-319-45378-1_26⟩. ⟨hal-01637497⟩
110 Consultations
80 Téléchargements
