Abstract : This article presents a proposal of solution for the problem of optimization of the virtual machine (VM) backup or replication process in architecture with multiple locations where efficient bandwidth usage and maximal tardiness for single VM are objectives. The two step algorithm is considered, where in the first step a set of tasks is partitioned into smaller subsets for load balancing. In the second step - tabu search algorithm is used to minimize weighted sum of tardiness. The paper contains the results of computational experiments on the scalability of the presented method.
https://hal.inria.fr/hal-01637508 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, November 17, 2017 - 3:45:38 PM Last modification on : Wednesday, November 22, 2017 - 10:41:19 AM Long-term archiving on: : Sunday, February 18, 2018 - 2:55:59 PM
Wojciech Bożejko, Piotr Nadybski, Mieczysław Wodecki. Two Step Algorithm for Virtual Machine Distributed Replication with Limited Bandwidth Problem. 15th IFIP International Conference on Computer Information Systems and Industrial Management (CISIM), Sep 2016, Vilnius, Lithuania. pp.312-321, ⟨10.1007/978-3-319-45378-1_28⟩. ⟨hal-01637508⟩
