Conference papers
Optimal Ellipse Based Algorithm as an Approximate and Robust Solution of Minimum Volume Covering Ellipse Problem
Abstract : We propose a algorithm to give a approximate solution of a minimal covering circle or ellipse of a set of points. The iterative algorithm is based on the optimal ellipse which best describe a given set of points.
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/hal-01637514
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Friday, November 17, 2017 - 3:45:57 PM
Last modification on : Tuesday, December 7, 2021 - 3:33:15 PM
Long-term archiving on: : Sunday, February 18, 2018 - 3:20:06 PM
File
419526_1_En_22_Chapter.pdf
Identifiers
Collections
Citation
Krzysztof Misztal, Jacek Tabor, Jakub Hyła. Optimal Ellipse Based Algorithm as an Approximate and Robust Solution of Minimum Volume Covering Ellipse Problem. 15th IFIP International Conference on Computer Information Systems and Industrial Management (CISIM), Sep 2016, Vilnius, Lithuania. pp.240-250, ⟨10.1007/978-3-319-45378-1_22⟩. ⟨hal-01637514⟩
Share
Metrics
Record views
40
Files downloads
124
