M. Hu, Visual pattern recognition by moment invariants Information Theory, IRE Transactions, issue.82, pp.179-187, 1962.
H. Maas and G. Vosselman, Two algorithms for extracting building models from raw laser altimetry data, ISPRS Journal of Photogrammetry and Remote Sensing, vol.54, issue.2-3, pp.153-163, 1999.
DOI : 10.1016/S0924-2716(99)00004-0
[. Gross, U. Demantke, C. Mallet, N. David, and B. Vallet, Extraction of lines from laser point clouds. ISPRS Commission III Photogrammetric Computer Vision PCV, Dimensionality based scale selection in 3D lidar point clouds. ISPRS Commission III -WG III, 2006.
[. Goggin, D. C. Jupiter, and M. Czerwinski, Simple Computed Tomography???Based Calculations of Orbital Floor Fracture Defect Size Are Not Sufficiently Accurate for Clinical Use, Journal of Oral and Maxillofacial Surgery, vol.73, issue.1, pp.112-116, 2015.
DOI : 10.1016/j.joms.2014.08.002
[. Ploder, C. Klug, M. Voracek, G. Burggasser, and C. Czerny, Evaluation of computer-based area and volume measurement from coronal computed tomography scans in isolated blowout fractures of the orbital floor, Journal of Oral and Maxillofacial Surgery, vol.60, issue.11, pp.1267-1272, 2002.
DOI : 10.1053/joms.2002.35722
E. W. Dijkstra59-]-dijkstra, A note on two problems in connexion with graphs, Numerische Mathematik, vol.4, issue.1, pp.269-271
DOI : 10.1007/BF01386390
