Abstract : Complex user's needs often require heterogeneous services to be combined together. In this paper, we explore a novel approach to enable flexible and dynamic composition of heterogeneous services for end users who are usually not familiar with technical process models. End-users are only required to model their goals and semantic reasoning is used for the composition itself. The possible service compositions are expressed in BPMN in order to be then processed by a BPMN engine. Since the composition is built on-the-fly, this approach avoids static linking of services and therefore is much more flexible.
https://hal.inria.fr/hal-01638390
Contributor : Isabelle Mirbel <>
Submitted on : Thursday, November 23, 2017 - 5:03:20 PM Last modification on : Monday, October 12, 2020 - 10:30:35 AM
Isabelle Mirbel. From user goals to process-based service compositions: A flexible semantic-based approach. RCIS 2017 - 11th International Conference on Research Challenges in Information Science, May 2017, Brighton, United Kingdom. ⟨hal-01638390⟩
