An Evaluation of Similarity Coefficients for Software Fault Localization, 2006 12th Pacific Rim International Symposium on Dependable Computing (PRDC'06), pp.39-46, 2006. ,
DOI : 10.1109/PRDC.2006.18
On the accuracy of spectrumbased fault localization, Testing: Academic and Industrial Conference Practice and Research Techniques -MUTATION, pp.89-98, 2007. ,
Fault-localization techniques for software systems, ACM SIGSOFT Software Engineering Notes, vol.39, issue.5, pp.1-8, 2014. ,
DOI : 10.1145/2659118.2659125
Debugging with dynamic slicing and backtracking. Software Practice and Experience, pp.589-616, 1993. ,
DOI : 10.1002/spe.4380230603
URL : http://www.cs.ubc.ca/local/reading/proceedings/spe91-95/spe/./vol23/issue6/spe832.pdf
Dynamic program slicing, Proc. of ACM SIG- PLAN 1990 Conference on Programming Language Design and Implementation, PLDI '90, pp.246-256, 1990. ,
A framework for automated testing of javascript web applications, Proceeding of the 33rd international conference on Software engineering, ICSE '11, pp.571-580, 2011. ,
DOI : 10.1145/1985793.1985871
Directed test generation for effective fault localization, Proceedings of the 19th international symposium on Software testing and analysis, ISSTA '10, pp.49-60, 2010. ,
DOI : 10.1145/1831708.1831715
Fault localization for dynamic web applications. Software Engineering, IEEE Transactions on, vol.38, issue.2, pp.314-335, 2012. ,
DOI : 10.1109/tse.2011.76
Finding bugs in web applications using dynamic test generation and explicit-state model checking. Software Engineering, IEEE Transactions on, vol.36, issue.4, pp.474-494, 2010. ,
DOI : 10.1109/tse.2010.31
URL : http://people.csail.mit.edu/mernst/pubs/bugs-webapps-tse2010.pdf
From symptom to cause: Localizing errors in counterexample traces, Proc. of 30th ACM SIGPLAN-SIGACT Symposium on Principles of Programming Languages, POPL '03, pp.97-105, 2003. ,
The Palladio component model for model-driven performance prediction, Journal of Systems and Software, vol.82, issue.1, pp.3-22, 2009. ,
DOI : 10.1016/j.jss.2008.03.066
Performance Prediction of Component-Based Systems, Architecting Systems with Trustworthy Components, pp.169-192, 2006. ,
DOI : 10.1016/j.entcs.2005.04.036
PBlaman: performance blame analysis based on Palladio contracts, Concurrency and Computation: Practice and Experience, vol.5581, issue.6, pp.1975-2004, 2014. ,
DOI : 10.1007/978-3-642-02351-4_4
Pinpoint: problem determination in large, dynamic Internet services, Proceedings International Conference on Dependable Systems and Networks, pp.595-604, 2002. ,
DOI : 10.1109/DSN.2002.1029005
Flow-Sensitive Fault Localization, Verification, Model Checking, and Abstract Interpretation, pp.189-208, 2013. ,
DOI : 10.1007/978-3-642-35873-9_13
URL : http://cs.nyu.edu/wies/publ/flow-sensitive_fault_localization.pdf
A Tool for Checking ANSI-C Programs, Tools and Algorithms for the Construction and Analysis of Systems, pp.168-176, 2004. ,
DOI : 10.1007/978-3-540-24730-2_15
Locating causes of program failures, Proc. of 27th International Conference on Software Engineering, ICSE '05, pp.342-351, 2005. ,
DOI : 10.1145/1062455.1062522
URL : http://pag.csail.mit.edu/reading-group/cleve05locating.pdf
Component-based development process and component lifecycle, ICSEA, p.44, 2006. ,
DOI : 10.1109/icsea.2006.261300
URL : http://cit.fer.hr/index.php/CIT/article/download/1586/1290/
Lightweight Defect Localization for Java, ECOOP 2005 -Object-Oriented Programming, pp.528-550, 2005. ,
DOI : 10.1007/11531142_23
URL : https://www.st.cs.uni-saarland.de/~dallmeier/pub/papers/ecoop05.pdf
Yices??2.2, Computer Aided Verification, pp.737-744, 2014. ,
DOI : 10.1007/978-3-319-08867-9_49
Assuring Consistency of Business Process Models and Web Services Using Visual Contracts, LNCS, vol.44, issue.1, pp.17-31, 2007. ,
DOI : 10.1147/sj.441.0047
URL : http://is.uni-paderborn.de/uploads/tx_sibibtex/Assuring_Consistency_of_Business_Process_Models_and_Web_Services_using_Visual_Contracts.pdf
Error Invariants, FM 2012: Formal Methods, pp.187-201, 2012. ,
DOI : 10.1007/978-3-642-32759-9_17
Error explanation with distance metrics, International Journal on Software Tools for Technology Transfer, vol.28, issue.2, pp.229-247, 2006. ,
DOI : 10.1007/s10009-005-0202-0
Making the Most of BMC Counterexamples, Electronic Notes in Theoretical Computer Science, vol.119, issue.2, pp.67-81, 2005. ,
DOI : 10.1016/j.entcs.2004.12.023
Experiments on the effectiveness of dataflow- and control-flow-based test adequacy criteria, Proceedings of 16th International Conference on Software Engineering, pp.191-200, 1994. ,
DOI : 10.1109/ICSE.1994.296778
Empirical evaluation of the tarantula automatic faultlocalization technique, Proc. of 20th IEEE/ACM International Conference on Automated Software Engineering, ASE '05, pp.273-282, 2005. ,
Visualization of test information to assist fault localization, Proceedings of the 24th international conference on Software engineering , ICSE '02, pp.467-477, 2002. ,
DOI : 10.1145/581396.581397
Cause clue clauses, ACM SIGPLAN Notices, vol.46, issue.6, pp.437-446, 2011. ,
DOI : 10.1145/1993316.1993550
Cause clue clauses: Error localization using maximum satisfiability, Proc. of 32Nd ACM SIGPLAN Conference on Programming Language Design and Implementation, PLDI '11, pp.437-446, 2011. ,
Automated error localization and correction for imperative programs, Proc. of International Conference on Formal Methods in Computer-Aided Design, pp.91-100, 2011. ,
Dynamic program slicing, Information Processing Letters, vol.29, issue.3, pp.155-163, 1988. ,
DOI : 10.1016/0020-0190(88)90054-3
URL : http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.158.9078&rep=rep1&type=pdf
A Formula-Based Approach for Automatic Fault Localization of Imperative Programs, Formal Methods and Software Engineering, pp.251-266 ,
DOI : 10.1007/978-3-319-11737-9_17
Bug isolation via remote program sampling, ACM SIGPLAN Notices, vol.38, issue.5, pp.141-154, 2003. ,
DOI : 10.1145/780822.781148
Bug isolation via remote program sampling, Proc. of ACM SIGPLAN 2003 Conference on Programming Language Design and Implementation, PLDI '03, pp.141-154, 2003. ,
DOI : 10.1145/781131.781148
Scalable statistical bug isolation, Proc. of 2005 ACM SIGPLAN Conference on Programming Language Design and Implementation, PLDI '05, pp.15-26, 2005. ,
DOI : 10.1145/1065010.1065014
Scalable statistical bug isolation, ACM SIGPLAN Notices, vol.40, issue.6, pp.15-26, 2005. ,
DOI : 10.1145/1064978.1065014
Slicing Web service-based software, 2009 IEEE International Conference on Service-Oriented Computing and Applications (SOCA), pp.1-8, 2009. ,
DOI : 10.1109/SOCA.2009.5410460
Static approximation of dynamically generated Web pages, Proceedings of the 14th international conference on World Wide Web , WWW '05, pp.432-441, 2005. ,
DOI : 10.1145/1060745.1060809
URL : http://www.www2005.org/cdrom/docs/p432.pdf
A reliability model for Service Component Architectures, Journal of Systems and Software, vol.89, pp.109-127, 2014. ,
DOI : 10.1016/j.jss.2013.11.002
Fault localization with nearest neighbor queries, 18th IEEE International Conference on Automated Software Engineering, 2003. Proceedings., pp.30-39, 2003. ,
DOI : 10.1109/ASE.2003.1240292
URL : http://www.cs.brown.edu/people/er/papers/./renieris-ase2003.pdf
Model-driven development with mechatronic UML ,
Expertise in Debugging Computer Programs: An Analysis of the Content of Verbal Protocols, IEEE Transactions on Systems, Man, and Cybernetics, vol.16, issue.5, pp.621-637, 1986. ,
DOI : 10.1109/TSMC.1986.289308
Knowledge-Based Verification of Service Compositions -- An SMT Approach, 2013 18th International Conference on Engineering of Complex Computer Systems, pp.24-32, 2013. ,
DOI : 10.1109/ICECCS.2013.14
URL : http://www.cs.uni-paderborn.de/uploads/tx_sibibtex/Knowledge-based_Verification_of_Service.pdf
Dynamic test input generation for web applications, Proceedings of the 2008 international symposium on Software testing and analysis, ISSTA '08, pp.249-260, 2008. ,
DOI : 10.1145/1390630.1390661
Program Slicing, Proc. of 5th International Conference on Software Engineering, ICSE '81, pp.439-449, 1981. ,
DOI : 10.1109/TSE.1984.5010248
A Survey on Software Fault Localization, IEEE Transactions on Software Engineering, vol.42, issue.8, 2009. ,
DOI : 10.1109/TSE.2016.2521368
URL : http://www.utdallas.edu/%7Eewong/fault-localization-survey.pdf
Automated debugging based on a constraint model of the program and a test case, The Journal of Logic and Algebraic Programming, vol.81, issue.4, pp.390-407, 2009. ,
DOI : 10.1016/j.jlap.2012.03.002
Yesterday, my program worked. today, it does not. why, ESEC/FSE, pp.253-267, 1999. ,
DOI : 10.1145/318774.318946
URL : http://www.infosun.fmi.uni-passau.de/st/papers/tr-99-01/tr-99-01.ps.gz
Isolating cause-effect chains from computer programs, Proc. of 10th ACM SIGSOFT Symposium on Foundations of Software Engineering, SIGSOFT '02/FSE-10, pp.1-10, 2002. ,
DOI : 10.1145/587051.587053
Simplifying and isolating failure-inducing input, IEEE Transactions on Software Engineering, vol.28, issue.2, pp.183-200, 2002. ,
DOI : 10.1109/32.988498
Experimental evaluation of using dynamic slices for fault location, Proceedings of the Sixth sixth international symposium on Automated analysis-driven debugging , AADEBUG'05, pp.33-42, 2005. ,
DOI : 10.1145/1085130.1085135
