Interplay of Virtual Machine Selection and Virtual Machine Placement
Previous work on optimizing resource provisioning in virtualized environments focused either on mapping virtual machines to physical machines (i.e., virtual machine placement) or mapping computational tasks to virtual machines (i.e., virtual machine selection). In this paper, we investigate how these two optimization problems influence each other. Our study shows that exploiting knowledge about the physical machines and about the virtual machine placement algorithm in the course of virtual machine selection leads to better overall results than considering the two problems in isolation.
Informatique [cs]
