A new, rare and distinctive species of Panorthoptera (Insecta, Archaeorthoptera) from the Upper Carboniferous of Xiaheyan (Ningxia, China) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Fossil Record Année : 2017
The Xiaheyan locality is providing abundant material on one of the earliest insect faunas. The most common species are comparatively remote relatives of Orthoptera (grasshoppers, crickets and katydids), belonging to the Ar-chaeorthoptera nec Panorthoptera (the latter including crown Orthoptera). We establish the genus Sinogerarus gen. nov. to accommodate a new, rare species, S. pectinatus spec. nov., which can be conclusively assigned to Panorthoptera. It therefore represents the second occurrence of the group at this locality. The new species displays a distinctive combination of character states, adding to the knowledge of a number of Upper Carboniferous Panorthoptera whose relationships are poorly understood.
Paléontologie
fr-20-253-2017.pdf (1.9 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-01638604 , version 1 (20-11-2017)
Jun-Jie Gu, Olivier Bethoux, Dong Ren. A new, rare and distinctive species of Panorthoptera (Insecta, Archaeorthoptera) from the Upper Carboniferous of Xiaheyan (Ningxia, China). Fossil Record, 2017, 20 (2), pp.253 - 257. ⟨10.5194/fr-20-253-2017⟩. ⟨hal-01638604⟩
255 Consultations
90 Téléchargements
