A Formal Proof in Coq of a Control Function for the Inverted Pendulum - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Damien Rouhling
Control theory provides techniques to design controllers, or control functions, for dynamical systems with inputs, so as to grant a particular behaviour of such a system. The inverted pendulum is a classic system in control theory: it is used as a benchmark for nonlinear control techniques and is a model for several other systems with various applications. We formalized in the Coq proof assistant the proof of soundness of a control function for the inverted pendulum. This is a first step towards the formal verification of more complex systems for which safety may be critical.
poplws18cppmain-id41-p-ef0777f-34741-final.pdf (897.3 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-01639819 , version 1 (26-11-2017)
hal-01639819 , version 2 (22-01-2018)
Damien Rouhling. A Formal Proof in Coq of a Control Function for the Inverted Pendulum. CPP 2018 - 7th ACM SIGPLAN International Conference on Certified Programs and Proofs, Jan 2018, Los Angeles, United States. pp.1-14, ⟨10.1145/3167101⟩. ⟨hal-01639819v2⟩
295 Consultations
936 Téléchargements
