QuP, Proceedings of International Workshop on Massively Multiuser Virtual Environments, GPGPU-7, 2014. ,
DOI : 10.1145/2594448.2577389
Budget based dynamic state update aggregation, Proceedings of the 7th ACM International Workshop on Massively Multiuser Virtual Environments, MMVE '15, pp.25-26, 2015. ,
DOI : 10.1145/2594448.2577396
URL : http://users.informatik.haw-hamburg.de/%7Eubicomp/arbeiten/papers/MMVE-15.pdf
A Weekend of Epic Destruction in EVE On- line (2013), http://community.eveonline.com/news/dev-blogs/ a-weekend-of-epic-destruction-in-eve-online ,
Locality aware dynamic load management for massively multiplayer games, Proceedings of the tenth ACM SIGPLAN symposium on Principles and practice of parallel programming , PPoPP '05, 2005. ,
DOI : 10.1145/1065944.1065982
Dynamic microcell assignment for massively multiplayer online gaming, Proceedings of 4th ACM SIGCOMM workshop on Network and system support for games , NetGames '05, 2005. ,
DOI : 10.1145/1103599.1103611
Dynamic load balancing in distributed virtual environments using heat diffusion, ACM Transactions on Multimedia Computing, Communications, and Applications, vol.10, issue.2, pp.1-19, 2014. ,
DOI : 10.1109/71.243526
A New Representation and Operators for Genetic Algorithms Applied to Grouping Problems, Evolutionary Computation, vol.2, issue.2, pp.123-144, 1994. ,
DOI : 10.1162/evco.1994.2.2.123
URL : http://www.mitpressjournals.org/userimages/ContentEditor/1164817256746/lib_rec_form.pdf
Hybrid load balancing for online games, Proceedings of the international conference on Multimedia, MM '10, p.1231, 2010. ,
DOI : 10.1145/1873951.1874194
URL : http://www.cs.cityu.edu.hk/%7Erynson/papers/mm10.pdf
Load balancing for massively multiplayer online games on Network and system support for games -NetGames '06. p. 1, Proceedings of 5th ACM SIGCOMM workshop, 2006. ,
DOI : 10.1145/1230040.1230064
An efficient partitioning algorithm for distributed virtual environment systems, IEEE Transactions on Parallel and Distributed Systems, vol.13, issue.3, pp.193-211, 2002. ,
DOI : 10.1109/71.993202
URL : http://www.cse.cuhk.edu.hk/~cslui/PUBLICATION/ieee_tpds_2002_dve.pdf
An ACS-based partitioning method for distributed virtual environment systems, Proceedings International Parallel and Distributed Processing Symposium, 2003. ,
DOI : 10.1109/IPDPS.2003.1213283
An adaptive load balancing technique for distributed virtual environment systems, Proceedings of the IASTED International Conference on Parallel and Distributed Computing and Systems (PCDS'03, pp.256-261, 2003. ,
A multi-server architecture for distributed virtual walkthrough, Proceedings of the ACM symposium on Virtual reality software and technology , VRST '02, p.163, 2002. ,
DOI : 10.1145/585740.585768
ALVIC-NG: state management and immersive communication for massively multiplayer online games and communities, Multimedia Tools and Applications, vol.42, issue.4, pp.109-131, 2009. ,
DOI : 10.1007/s11042-009-0299-3
On Delay Adjustment for Dynamic Load Balancing in Distributed Virtual Environments, IEEE Transactions on Visualization and Computer Graphics, vol.18, issue.4, pp.529-537, 2012. ,
DOI : 10.1109/TVCG.2012.52
