Abstract : This paper describes the evaluation of three different scenarios in the fully immersive room-based virtual environment DAVE (Definitely Affordable Virtual Environment) and a head-mounted display, the Oculus Rift. The evaluation focuses on comparing the two immersive environments and three different scenarios (observation, emotion in a roller coaster, and interaction) in regards to typical virtual-reality characteristics, such as immersion, engagement, but also on cybersickness and the overall experience. First results indicate the DAVE environment better supports scenarios, which require the user to directly interact with the environment. The roller coaster scenario creates stronger immersion and a higher nausea-level, while the interactive task is more engaging in terms of fun.
https://hal.inria.fr/hal-01640299 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, November 20, 2017 - 5:05:43 PM Last modification on : Tuesday, November 21, 2017 - 10:09:05 AM Long-term archiving on: : Wednesday, February 21, 2018 - 3:30:57 PM
Volker Settgast, Johanna Pirker, Stefan Lontschar, Stefan Maggale, Christian Gütl. Evaluating Experiences in Different Virtual Reality Setups. 15th International Conference on Entertainment Computing (ICEC), Sep 2016, Wien, Austria. pp.115-125, ⟨10.1007/978-3-319-46100-7_10⟩. ⟨hal-01640299⟩
