Articulatory model of the epiglottis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This works describes the construction of the articulatory model of the epiglottis from MRI images. This new model takes into account the influences of the mandible, tongue and larynx via a multi-linear regression applied to the contours of the epiglottis. Once these influences are removed from the contours principle component analysis is applied to the control points of the B-spline representing the centerline of the epiglottis.
epiglottisISSP.pdf (519.11 Ko) Télécharger le fichier
hal-01643227 , version 1 (21-11-2017)
  • HAL Id : hal-01643227 , version 1
Yves Laprie, Benjamin Elie, Pierre-André Vuissoz, Anastasiia Tsukanova. Articulatory model of the epiglottis. The 11th International Seminar on Speech Production, Oct 2017, Tianjin, China. ⟨hal-01643227⟩
153 Consultations
120 Téléchargements
