Direct kinematics of CDPR with extra cable orientation sensors: the 2 and 3 cables case with perfect measurement and ideal or elastic cables - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Direct kinematics (DK) of cable-driven parallel robots (CDPR) based only on cable lengths measurements is a complex issue even with ideal cables and consequently even harder for more realistic cable models. A natural way to simplify the DK solving is to add sensors. We consider here sensors that give a partial or complete measurement of the cable direction at the anchor points and spatial CDPR with 2/3 cables and we assume that these measurements are exact. We provide a solving procedure and maximal number of DK solutions for an extensive combination of sensors while considering two different cables models: ideal and linearly elastic without deformation.
cablecon2017.pdf (192.5 Ko) Télécharger le fichier
hal-01643451 , version 1 (21-11-2017)
  • HAL Id : hal-01643451 , version 1
Jean-Pierre Merlet. Direct kinematics of CDPR with extra cable orientation sensors: the 2 and 3 cables case with perfect measurement and ideal or elastic cables. CableCon 2017 - Third International Conference on Cable-Driven Parallel Robots, Aug 2017, Quebec, Canada. ⟨hal-01643451⟩
99 Consultations
174 Téléchargements
