Computing cross-sections of the workspace of cable-driven parallel robots with 6 sagging cables - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Finding the workspace of cable driven parallel robots (CDPR) with sagging cables (i.e. elastic and deformable cables) is a problem that has never been fully addressed in the literature as this is a complex issue: the inverse kinematics may have multiple solutions and the equations that describe the problem are non-linear and non algebraic. We address here the problem of determining an approximation of the border of horizontal cross-sections of the workspace for CDPR with 6 cables. We present an algorithm that give an outline of this border but also rises several theoretical issues. We then propose another algorithm that allow to determine a polygonal approximation of the workspace border induced by a specific constraint. All these algorithms are illustrated on a very large CDPR.
ck2017.pdf (121.53 Ko) Télécharger le fichier
hal-01643456 , version 1 (21-11-2017)
  • HAL Id : hal-01643456 , version 1
Jean-Pierre Merlet. Computing cross-sections of the workspace of cable-driven parallel robots with 6 sagging cables. CK 2017 - Computational Kinematics, May 2017, Poitiers, France. ⟨hal-01643456⟩
268 Consultations
240 Téléchargements
