The NIST SPIDER, A robot crane, Journal of Research of the National Institute of Standards and Technology, vol.97, issue.3, pp.373-385, 1992. ,
DOI : 10.6028/jres.097.016
URL : http://doi.org/10.6028/jres.097.016
IPAnema: a family of cable-driven parallel robots for industrial applications, 1st Int. Conf. on cable-driven parallel robots (CableCon), pp.119-134, 2012. ,
A portable parallel manipulator for search and rescue at large-scale urban earthquakes and an identification algorithm for the installation in unstructured environments, Proceedings 1999 IEEE/RSJ International Conference on Intelligent Robots and Systems. Human and Environment Friendly Robots with High Intelligence and Emotional Quotients (Cat. No.99CH36289), pp.17-21, 1999. ,
DOI : 10.1109/IROS.1999.812846
A portable, modular parallel wire crane for rescue operations, 2010 IEEE International Conference on Robotics and Automation, pp.2834-2839, 2010. ,
DOI : 10.1109/ROBOT.2010.5509299
URL : https://hal.archives-ouvertes.fr/hal-00987462
MARIONET, A Family of Modular Wire-Driven Parallel Robots, ARK, Piran, pp.53-62, 2010. ,
DOI : 10.1007/978-90-481-9262-5_6
Parallel manipulators, New Developments. ITECH, ch. Wire robot part II, dynamics, control & applications, pp.133-152, 2008. ,
Robust PD Control Using Adaptive Compensation for Completely Restrained Parallel-Wire Driven Robots: Translational Systems Using the Minimum Number of Wires Under Zero-Gravity Condition, IEEE Transactions on Robotics, vol.23, issue.4, pp.803-811, 2007. ,
DOI : 10.1109/TRO.2007.900633
System identification and cable force control for a cable-driven parallel robot with industrial servo drives, 2014 IEEE International Conference on Robotics and Automation (ICRA), pp.5921-5926, 2014. ,
DOI : 10.1109/ICRA.2014.6907731
Design and control of a redundant suspended cabledriven parallel robot, ARK, pp.237-244, 2012. ,
Vision-based modeling and control of large-dimension cable-driven parallel robots, 2012 IEEE/RSJ International Conference on Intelligent Robots and Systems, pp.1581-1586, 2012. ,
DOI : 10.1109/IROS.2012.6385504
URL : https://hal.archives-ouvertes.fr/hal-00768486
ARACHNIS: analysis of robots actuated by cables with handy and neat interface software, 2nd Int. Conf. on cabledriven parallel robots (CableCon), pp.293-306, 2014. ,
Modeling and real-time dynamic simulation of the cable-driven parallel robot IPAnema, 3rd European Conf. on Mechanism Science (Eucomes), pp.353-360, 2010. ,
Discrete trajectory control algorithms for NIMS3D, an autonomous underconstrained three-dimensional cabled robot, 2007 IEEE/RSJ International Conference on Intelligent Robots and Systems, pp.253-240, 2007. ,
DOI : 10.1109/IROS.2007.4399112
URL : http://cres.usc.edu/pubdb_html/files_upload/554.pdf
Real solutions of the direct geometrico-static problem of underconstrained cable-driven parallel robot with 3 cables: a numerical investigation Solving the direct geometricostatic problem of underconstrained cable-driven parallel robots by interval analysis, Meccanica Int. J. of Robotics Research, vol.473, issue.35 6, pp.1761-1773, 2012. ,
Direct geometrico-static problem of under-constrained cable-driven parallel robots with three cables, 2011 IEEE International Conference on Robotics and Automation, pp.3011-3017, 2011. ,
DOI : 10.1109/ICRA.2011.5979762
Direct Geometrico-Static Analysis of Under-Constrained Cable-Driven Parallel Robots with 4 Cables, 1st Int. Conf. on cable-driven parallel robots (CableCon), pp.269-286, 2012. ,
DOI : 10.1007/978-3-642-31988-4_17
Stability Analysis of Underconstrained Cable-Driven Parallel Robots, IEEE Transactions on Robotics, vol.29, issue.1, pp.288-296, 2013. ,
DOI : 10.1109/TRO.2012.2217795
URL : https://hal.archives-ouvertes.fr/hal-01425222
Stiness modeling and stability analysis of cable-suspended manipulators with elastic cable for maximum load determination, Kuwait J. Sci. Eng, vol.37, issue.1b, pp.181-201, 2010. ,
Optimization of the prestress stable wrench closure workspace of planar parallel three-degree-of-freedom cable-driven mechanisms with four cables, 2010 IEEE International Conference on Robotics and Automation, pp.1182-1187, 2010. ,
DOI : 10.1109/ROBOT.2010.5509351
Iterative-analytic redundancy resolution scheme for a cable-driven redundant parallel manipulator, 2010 IEEE/ASME International Conference on Advanced Intelligent Mechatronics, 2010. ,
DOI : 10.1109/AIM.2010.5695810
Parallel manipulators, New Developments. ITECH Wire robot part I, kinematics, analysis and design, pp.109-132, 2008. ,
Minimum-norm Solution for the Actuator Forces in Cable-based Parallel Manipulators based on Convex Optimization, Proceedings 2007 IEEE International Conference on Robotics and Automation, pp.1498-1503, 2007. ,
DOI : 10.1109/ROBOT.2007.363196
A real-time capable force calculation algorithm for redundant tendon-based parallel manipulators, 2008 IEEE International Conference on Robotics and Automation, pp.3869-3874, 2008. ,
DOI : 10.1109/ROBOT.2008.4543805
Closed-form Force Distribution for Parallel Wire Robots, Computational Kinematics, pp.25-34, 2009. ,
DOI : 10.1007/978-3-642-01947-0_4
On the inverse kinematics, statics, and fault tolerance of cable-suspended robots, Journal of Robotic Systems, vol.15, issue.10, pp.581-597, 1998. ,
DOI : 10.1002/(SICI)1097-4563(199810)15:10<581::AID-ROB4>3.0.CO;2-P
Optimal force distribution applied to a robotic crane with flexible cables, IEEE Int. Conf. on Robotics and Automation, pp.1948-1954, 2000. ,
An Analytic-Iterative Redundancy Resolution Scheme for Cable-Driven Redundant Parallel Manipulators, IEEE Transactions on Robotics, vol.27, issue.6, pp.670-676, 2011. ,
DOI : 10.1109/TRO.2011.2163433
Tension Distribution in Tendon-Based Stewart Platforms, ARK, Caldes de Malavalla, pp.117-124, 2002. ,
DOI : 10.1007/978-94-017-0657-5_13
URL : http://www.mechatronik.uni-duisburg.de/robotics/segesta/2002ark_paper.ps.gz
The Kantorovich Theorem for Newton's Method, The American Mathematical Monthly, vol.78, issue.4, pp.389-392, 1971. ,
DOI : 10.2307/2316909
ALIAS: an interval analysis based library for solving and analyzing system of equations, SEA, pp.14-16, 2000. ,
Simplified static analysis of large-dimension parallel cable-driven robots, 2012 IEEE International Conference on Robotics and Automation, pp.2299-2305, 2012. ,
DOI : 10.1109/ICRA.2012.6225159
URL : https://hal.archives-ouvertes.fr/lirmm-00737544
Introduction to Numerical Analysis, 2001. ,
DOI : 10.1017/CBO9780511612916
