Analyzing health quality survey using constrained co-clustering model for ordinal data and some dynamic implication - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
The dataset which motivated this work is a psychological survey on women affected by a breast tumor. Patients replied at different moments of their treatment to questionnaires with answers on ordinal scale. The questions relate to aspects of their life called dimensions. To assist the psychologists in analyzing the results, it is useful to emphasize a structure in the dataset. The clustering method achieves that by creating groups of individuals that are depicted by a representative of the group. From a psychological position , it is also useful to observe how questions may be grouped. This is why a clustering should be performed also on the features, which is called a co-clustering problem. However , gathering questions that are not related to the same dimension does not make sense from a psychologist stance. Therefore, a constrained co-clustering has been performed to prevent questions from different dimensions from getting assembled in a same column-cluster. Then, evolution of co-clusters along time has been investigated. The method relies on a constrained Latent Block Model embedding a probability distribution for ordinal data. Parameter estimation relies on a Stochastic EM-algorithm associated to a Gibbs sampler, and the ICL-BIC criterion is used for selecting the numbers of co-clusters.
constrained-clustering-ordinal.pdf (1014.83 Ko) Télécharger le fichier
hal-01643910 , version 1 (21-11-2017)
hal-01643910 , version 2 (27-07-2018)
hal-01643910 , version 3 (09-12-2019)
  • HAL Id : hal-01643910 , version 1
Margot Selosse, Julien Jacques, Christophe Biernacki, Florence Cousson-Gélie. Analyzing health quality survey using constrained co-clustering model for ordinal data and some dynamic implication. 2017. ⟨hal-01643910v1⟩
1102 Consultations
661 Téléchargements
