Toward perfect reads: self-correction of short reads via mapping on de Bruijn graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Short-read accuracy is important for downstream analyses such as genome assembly and hybrid long-read correction. Despite much work on short-read correction, present-day correctors either do not scale well on large data sets or consider reads as mere suites of k-mers, without taking into account their full-length read information. We propose a new method to correct short reads using de Bruijn graphs, and implement it as a tool called Bcool. As a first st ep, Bcool constructs a compacted de Bruijn graph from the reads. This graph is filtered on the basis of k-mer abundance then of unitig abundance, thereby removing from most sequencing errors. The cleaned graph is then used as a reference on which the reads are mapped to correct them. We show that this approach yields more accurate reads than k-mer-spectrum correctors while being scalable to human-size genomic datasets and beyond. The implementation is open source and available at http: //github.com/Malfoy/BCOOL under the Affero GPL license.
hal-01644163 , version 1 (22-11-2017)
Antoine Limasset, Jean-François Flot, Pierre Peterlongo. Toward perfect reads: self-correction of short reads via mapping on de Bruijn graphs. RECOMB 2018, Apr 2018, Paris, France. ⟨hal-01644163⟩
130 Consultations
0 Téléchargements
