Analytic expressions of the solutions of advection-diffusion problems in 1D with discontinuous coefficients
In this article, we provide a general methodology to compute the resolvent kernel as well as the density when available for a one-dimensional second-order differential operators with discontinuous coefficients. In a sequel, the computed resolvent kernel will be used to setup an efficient and accurate simulation scheme.
