Automatic loop interchange (with retrospective), Best of PLDI, pp.75-90, 1984. ,
DOI : 10.1145/502874.502897
TIMES: A??Tool for Schedulability Analysis and Code Generation of Real-Time Systems, Formal Modeling and Analysis of Timed Systems, pp.60-72, 2004. ,
DOI : 10.1007/978-3-540-40903-8_6
Syntax and Semantics of the Clock Constraint Specification Language (CCSL), 2009. ,
Extended Cyclostatic Dataflow Program Compilation and Execution for an Integrated Manycore Processor, Int. Conf. on Computational Science, pp.181624-1633, 2013. ,
DOI : 10.1016/j.procs.2013.05.330
URL : https://hal.archives-ouvertes.fr/hal-00832504
Hard-real-time scheduling of data-dependent tasks in embedded streaming applications, Proceedings of the ninth ACM international conference on Embedded software, EMSOFT '11, pp.195-204, 2011. ,
DOI : 10.1145/2038642.2038672
The synchronous languages 12 years later, Proceedings of the IEEE, pp.64-83, 2003. ,
DOI : 10.1109/JPROC.2002.805826
URL : http://www.cs.columbia.edu/~sedwards/papers/benveniste2003synchronous.pdf
Cyclo-static data flow, 1995 International Conference on Acoustics, Speech, and Signal Processing, pp.3255-3258, 1995. ,
DOI : 10.1109/ICASSP.1995.479579
Scheduling dynamic dataflow graphs with bounded memory using the token flow model, IEEE International Conference on Acoustics Speech and Signal Processing, 1993. ,
DOI : 10.1109/ICASSP.1993.319147
URL : http://ptolemy.eecs.berkeley.edu/oldwww/papers/tokenFlowICASSP93.ps.Z
Marked directed graphs, Journal of Computer and System Sciences, vol.5, issue.5, pp.511-523, 1971. ,
DOI : 10.1016/S0022-0000(71)80013-2
URL : https://doi.org/10.1016/s0022-0000(71)80013-2
Parallelism Reduction Based on Pattern Substitution in Dataflow Oriented Programming Languages, Proc. of the Int. Conf. on Computational Science, {ICCS'12}, pp.146-155, 2012. ,
DOI : 10.1016/j.procs.2012.04.016
URL : https://hal.archives-ouvertes.fr/hal-00706943
Back to basics: Homogeneous representations of multi-rate synchronous dataflow graphs, MEMOCODE, pp.35-46, 2013. ,
TimeSquare: Treat Your Models with Logical Time, TOOLS -50th Int. Conf. on Objects, Models, Components, Patterns -2012, pp.34-41, 2012. ,
DOI : 10.1007/978-3-642-30561-0_4
URL : https://hal.archives-ouvertes.fr/hal-00688590
RT-simex, Proceedings of the eighteenth ACM SIGSOFT international symposium on Foundations of software engineering, FSE '10, pp.377-378, 2010. ,
DOI : 10.1145/1882291.1882357
URL : https://hal.archives-ouvertes.fr/inria-00587116
Some efficient solutions to the affine scheduling problem. I. One-dimensional time, International Journal of Parallel Programming, vol.40, issue.6, pp.313-347, 1992. ,
DOI : 10.1145/360827.360844
SPDF: A schedulable parametric data-flow MoC, 2012 Design, Automation & Test in Europe Conference & Exhibition (DATE), pp.769-774, 2012. ,
DOI : 10.1109/DATE.2012.6176572
URL : https://hal.archives-ouvertes.fr/hal-00744376
Progressive and explicit refinement of scheduling for multidimensional data-flow applications using uml marte, Design Automation for Embedded Systems, vol.75, issue.9, pp.137-169, 2012. ,
DOI : 10.1109/ICECCS.2011.14
URL : https://hal.archives-ouvertes.fr/hal-00727239
Tool Support for the Analysis of TADL2 Timing Constraints Using TimeSquare, 2013 18th International Conference on Engineering of Complex Computer Systems, 2013. ,
DOI : 10.1109/ICECCS.2013.28
URL : https://hal.archives-ouvertes.fr/hal-00850673
The aethereal network on chip after ten years, Proceedings of the 47th Design Automation Conference on, DAC '10, pp.306-311, 2010. ,
DOI : 10.1145/1837274.1837353
Compiler Techniques for Scalable Performance of Stream Programs on Multicore Architectures, 2010. ,
Optimized rapid prototyping for real-time embedded heterogeneous multiprocessors, Proceedings of the seventh international workshop on Hardware/software codesign , CODES '99, 1999. ,
DOI : 10.1145/301177.301489
URL : http://www-rocq.inria.fr/syndex/pub/codes99/codes99.pdf
The semantics of a simple language for parallel programming, Inform. Process. 74: Proc. IFIP Congr. 74, pp.471-475, 1974. ,
Mppa manycore, 2014. ,
Heuristics for routing and spiral run-time task mapping in NoC-based heterogeneous MPSOCs, 1312. ,
Phased scheduling of stream programs, ACM SIGPLAN Notices, vol.38, issue.7, pp.103-112, 2003. ,
DOI : 10.1145/780731.780747
URL : http://cag.lcs.mit.edu/commit/papers/03/lctes-phased.ps
The Organization of Computations for Uniform Recurrence Equations, Journal of the ACM, vol.14, issue.3, pp.563-590, 1967. ,
DOI : 10.1145/321406.321418
Compaan, Proceedings of the eighth international workshop on Hardware/software codesign , CODES '00, pp.13-17, 2000. ,
DOI : 10.1145/334012.334015
The parallel execution of DO loops, Communications of the ACM, vol.17, issue.2, pp.83-93, 1974. ,
Static Scheduling of Synchronous Data Flow Programs for Digital Signal Processing, IEEE Transactions on Computers, vol.36, issue.1, pp.3624-3659, 1987. ,
DOI : 10.1109/TC.1987.5009446
Synchronous data flow, Proceedings of the IEEE, vol.75, issue.9, pp.1235-1245, 1987. ,
DOI : 10.1109/PROC.1987.13876
Safe CCSL Specifications and Marked Graphs, MEMOCODE -11th IEEE/ACM Int. Conf. on Formal Methods and Models for Codesign, pp.157-166, 2013. ,
DOI : 10.1007/978-3-642-41202-8_3
URL : https://hal.archives-ouvertes.fr/hal-00913962
Platform 2012, a many-core computing accelerator for embedded SoCs, Proceedings of the 49th Annual Design Automation Conference on, DAC '12, pp.1137-1142, 2012. ,
DOI : 10.1145/2228360.2228568
Periodic scheduling of marked graphs using balanced binary words, 33] R. Milner. A Calculus of Communicating Systems, pp.113-130, 1982. ,
DOI : 10.1016/j.tcs.2012.08.012
URL : https://hal.archives-ouvertes.fr/hal-00672606
Systematic and automated multiprocessor system design, programming, and implementation. Computer-Aided Design of Integrated Circuits and Systems, IEEE Transactions on, vol.27, issue.3, pp.542-555, 2008. ,
DOI : 10.1109/tcad.2007.911337
Transforming synchronous data-flow graphs to reduce execution time. Int'l, Journal of Computers and Their Applications, vol.18, issue.2, pp.111-122, 2011. ,
Kommunikation mit Automaten Griffiss Air Force Base, Institut für Instrumentelle Mathematik, 1962. ,
Embedded multiprocessors: Scheduling and synchronization, 2012. ,
DOI : 10.1201/9781420048025
Predictable Mapping of Streaming Applications on Multiprocessors, 2007. ,
Sdf3: Sdf for free, ACSD, pp.276-278, 2006. ,
DOI : 10.1109/acsd.2006.23
Parametric Schedulability Analysis of Fixed Priority Real-Time Distributed Systems, Formal Techniques for Safety-Critical Systems, pp.212-228, 2014. ,
DOI : 10.1007/978-3-319-05416-2_14
URL : http://www.lsv.ens-cachan.fr/Publis/PAPERS/PDF/SSLAF-ftscs13.pdf
Verifying MARTE/CCSL Mode Behaviors Using UPPAAL, Software Engineering and Formal Methods, pp.1-15, 2013. ,
DOI : 10.1007/978-3-642-40561-7_1
URL : https://hal.archives-ouvertes.fr/hal-00866477
Compiler-directed memory management for heterogeneous MPSoCs, Special Issue On-Chip Parallel And Network-Based Systems, pp.134-145, 2011. ,
DOI : 10.1016/j.sysarc.2010.10.008
URL : https://hal.archives-ouvertes.fr/hal-00747819
Verification of MARTE/CCSL Time Requirements in Promela/SPIN, 2011 16th IEEE International Conference on Engineering of Complex Computer Systems, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00650621
Polychronous controller synthesis from MARTE CCSL timing specifications, Ninth ACM/IEEE International Conference on Formal Methods and Models for Codesign (MEMPCODE2011), pp.21-30, 2011. ,
DOI : 10.1109/MEMCOD.2011.5970507
URL : https://hal.archives-ouvertes.fr/inria-00594942
