Scheduling data-intensive workflows on storage constrained resources, Proceedings of the 4th Workshop on Workflows in Support of Large-Scale Science, WORKS '09, 2009. ,
DOI : 10.1145/1645164.1645167
URL : http://www.isi.edu/~annc/papers/works2009.pdf
Recent advances in graph partitioning, Algorithm Engineering, pp.117-158, 2016. ,
Direct Methods for Sparse Linear Systems. Fundamentals of Algorithms, Society for Industrial and Applied Mathematics, 2006. ,
DOI : 10.1137/1.9780898718881
Shape-optimized mesh partitioning and load balancing for parallel adaptive FEM, Graph Partitioning and Parallel Computing, pp.1555-1581, 2000. ,
DOI : 10.1016/S0167-8191(00)00043-0
Algorithms for partitioning graphs and computer logic based on eigenvectors of connection matrices, IBM Technical Disclosure Bulletin, vol.15, issue.3, pp.938-944, 1972. ,
Lower Bounds for the Partitioning of Graphs, IBM Journal of Research and Development, vol.17, issue.5, pp.420-425, 1973. ,
DOI : 10.1147/rd.175.0420
Parallel Scheduling of Task Trees with Limited Memory, ACM Transactions on Parallel Computing, vol.2, issue.2, p.13, 2015. ,
DOI : 10.1145/321607.321620
URL : https://hal.archives-ouvertes.fr/hal-01160118
A linear-time heuristic for improving network partitions, 19th Design Automation Conference, pp.175-181, 1982. ,
DOI : 10.1145/800263.809204
URL : http://www.comp.nus.edu.sg/~cs5234/2007-08/Lectures/L07/paper-fm.pdf
Computers and Intractability; A Guide to the Theory of NP-Completeness, 1990. ,
On Optimal Tree Traversals for Sparse Matrix Factorization, 2011 IEEE International Parallel & Distributed Processing Symposium, pp.556-567, 2011. ,
DOI : 10.1109/IPDPS.2011.60
URL : https://hal.archives-ouvertes.fr/hal-00945078
An Efficient Heuristic Procedure for Partitioning Graphs, Bell System Technical Journal, vol.49, issue.2, pp.291-307, 1970. ,
DOI : 10.1002/j.1538-7305.1970.tb01770.x
Memory-optimal evaluation of expression trees involving large objects, Computer Languages, Systems & Structures, vol.37, issue.2, pp.63-75, 2011. ,
DOI : 10.1016/j.cl.2010.09.003
An automatic method for solving discrete programming problems. 50 Years of Integer Programming, pp.105-132, 1958. ,
DOI : 10.1007/978-3-540-68279-0_5
URL : http://jmvidal.cse.sc.edu/library/land60a.pdf
On the storage requirement in the out-of-core multifrontal method for sparse factorization, ACM Transactions on Mathematical Software, vol.12, issue.3, pp.249-264, 1986. ,
DOI : 10.1145/7921.11325
An Application of Generalized Tree Pebbling to Sparse Matrix Factorization, SIAM Journal on Algebraic Discrete Methods, vol.8, issue.3, 1987. ,
DOI : 10.1137/0608031
The Role of Elimination Trees in Sparse Factorization, SIAM Journal on Matrix Analysis and Applications, vol.11, issue.1, pp.134-172, 1990. ,
DOI : 10.1137/0611010
Random walks on graphs. Combinatorics, Paul erdos is eighty, pp.1-46, 1993. ,
A unified geometric approach to graph separators, [1991] Proceedings 32nd Annual Symposium of Foundations of Computer Science, pp.538-547, 1991. ,
DOI : 10.1109/SFCS.1991.185417
Scheduling dataintensiveworkflows onto storage-constrained distributed resources, CC- Grid'07, pp.401-409, 2007. ,
DOI : 10.1109/ccgrid.2007.101
URL : http://www.isi.edu/~deelman/ccgrid07.pdf
Multiple-way network partitioning, IEEE Transactions on Computers, vol.38, issue.1, pp.62-81, 1989. ,
DOI : 10.1109/12.8730
On partitioning FEM graphs using diffusion, 18th International Parallel and Distributed Processing Symposium, 2004. Proceedings., p.277, 2004. ,
DOI : 10.1109/IPDPS.2004.1303358
The Generation of Optimal Code for Arithmetic Expressions, Journal of the ACM, vol.17, issue.4, pp.715-728, 1970. ,
Partitioning of unstructured problems for parallel processing, Computing Systems in Engineering, vol.2, issue.2-3, pp.135-148, 1991. ,
DOI : 10.1016/0956-0521(91)90014-V
Streaming graph partitioning for large distributed graphs, Proceedings of the 18th ACM SIGKDD international conference on Knowledge discovery and data mining, KDD '12, pp.1222-1230 ,
DOI : 10.1145/2339530.2339722
URL : http://www.eecs.berkeley.edu/~isabelle/papers/kdd325-stanton.pdf
Inovallée 655 avenue de l'Europe Montbonnot 38334 Saint Ismier Cedex Publisher Inria Domaine de Voluceau -Rocquencourt BP 105 -78153 Le Chesnay Cedex inria, pp.249-6399 ,
