Fast solution of boundary integral equations for elasticity around a crack network: a comparative study
Because of the non-local nature of the integral kernels at play, the discretization of boundary integral equations leads to dense matrices, which would imply high computational complexity. Acceleration techniques, such as hierarchical matrix strategies combined with Adaptive Cross Approximation (ACA), are available in literature. Here we apply such a technique to the solution of an elastostatic problem, arising from industrial applications, posed at the surface of highly irregular cracks networks.
