The Class of Semi-Markov Accumulation Processes - Archive ouverte HAL Access content directly
Conference Papers Year : 2018
(1, 2) , (3)
1
2
3
In this paper, we introduce a new accumulation process, the Semi-Markov Accumulation Process (SMAP). This class of processes extends the framework of continuous-time Markov Additive Processes (MAPs) by allowing the underlying environmental component to be a semi-Markov process instead of a Markov process. Next, we follow an analytic approach to derive a Master Equation formula of the Renewal type that describes the evolution of SMAPs in time. We show that under exponential holding times, a matrix exponential form analogous to the matrix exponent of a MAP is attained. Finally, we consider an application of our results where closed-form solutions are rather easy to achieve.
samma-incaam17 - final final.pdf (99.4 Ko) Télécharger le fichier
Dates and versions
hal-01645122 , version 1 (22-11-2017)
Identifiers
Cite
Alain Jean-Marie, Eleni Vatamidou. The Class of Semi-Markov Accumulation Processes. 2nd International mini-symposium on Stochastic Models: Methods and Applications (SAMMA 2017), Tuan Phung-Duc; Ioannis Dimitriou; Eleni Vatamidou, Sep 2017, Thessaloniki, Greece. pp.#190002, ⟨10.1063/1.5043829⟩. ⟨hal-01645122⟩
160 View
133 Download
Share
