The Class of Semi-Markov Accumulation Processes
In this paper, we introduce a new accumulation process, the Semi-Markov Accumulation Process (SMAP). This class of processes extends the framework of continuous-time Markov Additive Processes (MAPs) by allowing the underlying environmental component to be a semi-Markov process instead of a Markov process. Next, we follow an analytic approach to derive a Master Equation formula of the Renewal type that describes the evolution of SMAPs in time. We show that under exponential holding times, a matrix exponential form analogous to the matrix exponent of a MAP is attained. Finally, we consider an application of our results where closed-form solutions are rather easy to achieve.
