A complete factorization method for scattering by periodic structures, Computing, pp.75-111, 2005. ,
DOI : 10.1007/s00607-004-0092-0
The factorization method in inverse scattering from periodic structures, Inverse Problems, vol.19, issue.5, pp.1195-1211, 2003. ,
DOI : 10.1088/0266-5611/19/5/311
MUSIC for Extended Scatterers as an Instance of the Factorization Method, SIAM Journal on Applied Mathematics, vol.70, issue.4, pp.1283-1304, 2009. ,
DOI : 10.1137/080737836
URL : https://hal.archives-ouvertes.fr/hal-00782980
Qualitative methods for heterogeneous media, theses, Ecole Doctorale Polytechnique, 2015. ,
Identifying defects in an unknown background using differential measurements, Inverse Problems and Imaging, vol.9, issue.3, pp.625-643, 2015. ,
DOI : 10.3934/ipi.2015.9.625
URL : https://hal.archives-ouvertes.fr/hal-01110270
A generalized formulation of the linear sampling method with exact characterization of targets in terms of farfield measurements, Inverse Problems, vol.30, issue.3, p.35011, 2014. ,
DOI : 10.1088/0266-5611/30/3/035011
URL : https://hal.archives-ouvertes.fr/hal-00911692
The factorization method applied to cracks with impedance boundary conditions, Inverse Problems and Imaging, vol.7, issue.4, 2013. ,
DOI : 10.3934/ipi.2013.7.1123
URL : https://hal.archives-ouvertes.fr/hal-00768729
On the identification of defects in a periodic waveguide from far field data, Inverse Problems, vol.30, issue.9, p.95004, 2014. ,
DOI : 10.1088/0266-5611/30/9/095004
URL : https://hal.archives-ouvertes.fr/hal-00914674
On the use of the linear sampling method to identify cracks in elastic waveguides, Inverse Problems, vol.29, issue.2, p.25017, 2013. ,
DOI : 10.1088/0266-5611/29/2/025017
URL : https://hal.archives-ouvertes.fr/hal-00937686
Qualitative Methods in Inverse Scattering Theory. An Introduction, 2006. ,
On the existence of transmission eigenvalues in an inhomogeneous medium, Applicable Analysis, vol.144, issue.4, pp.475-493, 2009. ,
DOI : 10.1007/978-1-4757-4393-7
URL : https://hal.archives-ouvertes.fr/hal-00743824
Transmission eigenvalues, Inverse Problems, vol.29, issue.10, p.100201, 2013. ,
DOI : 10.1088/0266-5611/29/10/100201
URL : https://hal.archives-ouvertes.fr/hal-00911761
The factorization method in inverse elastic scattering from penetrable bodies, Inverse Problems, vol.23, issue.1, pp.27-51, 2007. ,
DOI : 10.1088/0266-5611/23/1/002
Inverse acoustic and electromagnetic scattering theory, Applied Mathematical Sciences, vol.93, 2013. ,
DOI : 10.1007/978-3-662-03537-5
A simple method using Morozov's discrepancy principle for solving inverse scattering problems, Inverse Problems, vol.13, issue.6, pp.1477-1493, 1997. ,
DOI : 10.1088/0266-5611/13/6/005
Inverse scattering of elastic waves by periodic structures: uniqueness under the third or fourth kind boundary conditions, Methods and Applications of Analysis, pp.215-244, 2011. ,
Factorization method and irregular inclusions in electrical impedance tomography, Inverse Problems, vol.23, issue.5, pp.2159-2170, 2007. ,
DOI : 10.1088/0266-5611/23/5/020
Numerical analysis of the factorization method for EIT with a piecewise constant uncertain background, Inverse Problems, vol.29, issue.6, p.65009, 2013. ,
DOI : 10.1088/0266-5611/29/6/065009
URL : https://hal.archives-ouvertes.fr/hal-00768734
A volume integral method for solving scattering problems from locally perturbed infinite periodic layers, Applicable Analysis, vol.1, issue.1, p.29, 2016. ,
DOI : 10.1007/978-3-662-04796-5
URL : https://hal.archives-ouvertes.fr/hal-01374892
The Factorization Method for Electrical Impedance Tomography in the Half-Space, SIAM Journal on Applied Mathematics, vol.68, issue.4, pp.907-924, 2008. ,
DOI : 10.1137/06067064X
The factorization method for inverse elastic scattering from periodic structures, Inverse Problems, vol.29, issue.11, pp.29-115005, 2013. ,
DOI : 10.1088/0266-5611/29/11/115005
Characterization of the shape of a scattering obstacle using the spectral data of the far field operator, Inverse Problems, vol.14, issue.6, pp.1489-1512, 1998. ,
DOI : 10.1088/0266-5611/14/6/009
The Factorization Method for Inverse Problems, Oxford Lecture Series in Mathematics and its Applications 36, 2008. ,
DOI : 10.1093/acprof:oso/9780199213535.001.0001
A factorization method for an inverse Neumann problem for harmonic vector fields, Georgian Mathematical Journal, vol.10, pp.549-560, 2003. ,
Factorization Methods for Photonics and Rough Surface Scattering, 2008. ,
The factorization method applied to the complete electrode 6model of impedance tomography, pp.68-1097, 2008. ,
Factorization Method for Electromagnetic Inverse Scattering from Biperiodic Structures, SIAM Journal on Imaging Sciences, vol.6, issue.2, pp.1111-1139, 2013. ,
DOI : 10.1137/120903968
URL : http://hal.inria.fr/docs/00/76/29/39/PDF/inverse_3D.pdf
Spectral Methods for Direct and Inverse Scattering from Periodic Structures, 2012. ,
URL : https://hal.archives-ouvertes.fr/tel-00771746
Direct and inverse solvers for scattering problems from locally perturbed infinite periodic layers, theses, Ecole Polytechnique X, 2017. ,
The factorization method for inverse scattering from periodic inhomogeneous media, 2010. ,
Reconstruction of obstacles embedded in waveguides, Contemporary Mathematics, vol.586, pp.341-351, 2013. ,
DOI : 10.1090/conm/586/11652
Discreteness of Transmission Eigenvalues via Upper Triangular Compact Operators, SIAM Journal on Mathematical Analysis, vol.44, issue.1, pp.341-354, 2012. ,
DOI : 10.1137/110836420
URL : http://arxiv.org/pdf/1104.4336
A sampling method for the inverse transmission problem for periodic media, Inverse Problems, vol.28, issue.3, p.17, 2012. ,
DOI : 10.1088/0266-5611/28/3/035004
