On Multiplicative Transfer Function Approximation in the Short-Time Fourier Transform Domain, IEEE Signal Processing Letters, vol.14, issue.5, pp.337-340, 2007. ,
DOI : 10.1109/LSP.2006.888292
Signal enhancement using beamforming and nonstationarity with applications to speech, IEEE Transactions on Signal Processing, vol.49, issue.8, pp.1614-1626, 2001. ,
DOI : 10.1109/78.934132
URL : http://sipl.technion.ac.il/new/Pictures/Teaching/Projects/2002-3/MicArray-Gannot.pdf
Estimation of relative transfer function in the presence of stationary noise based on segmental power spectral density matrix subtraction, 2015 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.320-324, 2015. ,
DOI : 10.1109/ICASSP.2015.7177983
URL : https://hal.archives-ouvertes.fr/hal-01119186
Blind Separation of Speech Mixtures via Time-Frequency Masking, IEEE Transactions on Signal Processing, vol.52, issue.7, pp.1830-1847, 2004. ,
DOI : 10.1109/TSP.2004.828896
Model-Based Expectation-Maximization Source Separation and Localization, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.2, pp.382-394, 2010. ,
DOI : 10.1109/TASL.2009.2029711
URL : http://www.ee.columbia.edu/%7Eronw/pubs/taslp09-messl.pdf
MAP-Based Underdetermined Blind Source Separation of Convolutive Mixtures by Hierarchical Clustering and -Norm Minimization, EURASIP Journal on Advances in Signal Processing, vol.14, issue.4, pp.81-81, 2007. ,
DOI : 10.1109/TSA.2005.858005
A Consolidated Perspective on Multimicrophone Speech Enhancement and Source Separation, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.25, issue.4, pp.692-730, 2017. ,
DOI : 10.1109/TASLP.2016.2647702
URL : https://hal.archives-ouvertes.fr/hal-01414179
Beyond the Narrowband Approximation: Wideband Convex Methods for Under-Determined Reverberant Audio Source Separation, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.7, pp.1818-1829, 2010. ,
DOI : 10.1109/TASL.2010.2050089
URL : https://hal.archives-ouvertes.fr/hal-00435897
Sparse Reverberant Audio Source Separation via Reweighted Analysis, IEEE Transactions on Audio, Speech, and Language Processing, vol.21, issue.7, pp.1391-1402, 2013. ,
DOI : 10.1109/TASL.2013.2250962
URL : https://infoscience.epfl.ch/record/180378/files/tech-rep-SSCS.pdf
Inverse filtering of room acoustics, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.36, issue.2, pp.145-152, 1988. ,
DOI : 10.1109/29.1509
Multi-Channel Room Impulse Response Shaping - A Study, 2006 IEEE International Conference on Acoustics Speed and Signal Processing Proceedings, pp.101-104, 2006. ,
DOI : 10.1109/ICASSP.2006.1661222
URL : http://www.isip.uni-luebeck.de/uploads/tx_wapublications/Kallinger-Icassp06.pdf
Room Impulse Response Shortening/Reshaping With Infinity- and $p$-Norm Optimization, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.2, pp.249-259, 2010. ,
DOI : 10.1109/TASL.2009.2025789
URL : http://www.isip.uni-luebeck.de/uploads/tx_wapublications/IEEETASL2010-MMK.pdf
Regularization for Partial Multichannel Equalization for Speech Dereverberation, IEEE Transactions on Audio, Speech, and Language Processing, vol.21, issue.9, pp.1879-1890, 2013. ,
DOI : 10.1109/TASL.2013.2260743
Joint Dereverberation and Noise Reduction Based on Acoustic Multi-Channel Equalization, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.24, issue.4, pp.680-693, 2016. ,
DOI : 10.1109/TASLP.2016.2518804
Inverse Filtering for Speech Dereverberation Less Sensitive to Noise and Room Transfer Function Fluctuations, EURASIP Journal on Advances in Signal Processing, vol.9, issue.5, pp.1-12, 2007. ,
DOI : 10.1109/89.928915
URL : https://doi.org/10.1155/2007/34013
A blind channel identification-based two-stage approach to separation and dereverberation of speech signals in a reverberant environment, IEEE Transactions on Speech and Audio Processing, vol.13, issue.5, pp.882-895, 2005. ,
DOI : 10.1109/TSA.2005.851941
Recovering of broadband reverberant speech signal by sub-band MINT method, [Proceedings] ICASSP 91: 1991 International Conference on Acoustics, Speech, and Signal Processing, pp.969-972, 1991. ,
DOI : 10.1109/ICASSP.1991.150502
Realization of acoustic inverse filtering through multi-microphone sub-band processing, IEICE Transactions on Fundamentals of Electronics, Communications and Computer Sciences, vol.75, issue.11, pp.1474-1483, 1992. ,
Multichannel equalization in subbands, Proceedings of the 1999 IEEE Workshop on Applications of Signal Processing to Audio and Acoustics. WASPAA'99 (Cat. No.99TH8452), pp.203-206, 1999. ,
DOI : 10.1109/ASPAA.1999.810885
URL : http://www.bib.ecs.soton.ac.uk/data/2603/pdf/weiss99a.pdf
Equalization of Multichannel Acoustic Systems in Oversampled Subbands, IEEE Transactions on Audio, Speech, and Language Processing, vol.17, issue.6, pp.1061-1070, 2009. ,
DOI : 10.1109/TASL.2009.2015692
Robust speech dereverberation using subband multichannel least squares with variable relaxation, European Signal Processing Conference (EUSIPCO), 2013. ,
DOI : 10.1109/taslp.2014.2329632
System Identification in the Short-Time Fourier Transform Domain With Crossband Filtering, IEEE Transactions on Audio, Speech and Language Processing, vol.15, issue.4, pp.1305-1319, 2007. ,
DOI : 10.1109/TASL.2006.889720
Relative Transfer Function Identification Using Convolutive Transfer Function Approximation, IEEE Transactions on Audio, Speech, and Language Processing, vol.17, issue.4, pp.546-555, 2009. ,
DOI : 10.1109/TASL.2008.2009576
Convolutive Transfer Function Generalized Sidelobe Canceler, IEEE Transactions on Audio, Speech, and Language Processing, vol.17, issue.7, pp.1420-1434, 2009. ,
DOI : 10.1109/TASL.2009.2020891
Estimation of the Direct-Path Relative Transfer Function for Supervised Sound-Source Localization, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.24, issue.11, pp.2171-2186, 2016. ,
DOI : 10.1109/TASLP.2016.2598319
URL : https://hal.archives-ouvertes.fr/hal-01349691
Multiple-Speaker Localization Based on Direct-Path Features and Likelihood Maximization With Spatial Sparsity Regularization, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.25, issue.10, 1997. ,
DOI : 10.1109/TASLP.2017.2740001
URL : https://hal.archives-ouvertes.fr/hal-01413417
Audio source separation based on convolutive transfer function and frequency-domain lasso optimization, 2017 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), p.2017 ,
DOI : 10.1109/ICASSP.2017.7952214
URL : https://hal.archives-ouvertes.fr/hal-01430754
Multichannel audio source separation: Variational inference of time-frequency sources from time-domain observations, 2017 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), p.2017 ,
DOI : 10.1109/ICASSP.2017.7951791
URL : https://hal.archives-ouvertes.fr/hal-01416347
Separating time-frequency sources from time-domain convolutive mixtures using non-negative matrix factorization, 2017 IEEE Workshop on Applications of Signal Processing to Audio and Acoustics (WASPAA), 2017. ,
DOI : 10.1109/WASPAA.2017.8170036
URL : https://hal.archives-ouvertes.fr/hal-01548469
Multichannel High-Resolution NMF for Modeling Convolutive Mixtures of Non-Stationary Signals in the Time-Frequency Domain, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.22, issue.11, pp.1670-1680, 2014. ,
DOI : 10.1109/TASLP.2014.2341920
Online Speech Dereverberation Using Kalman Filter and EM Algorithm, IEEE Workshop on Applications of Signal Processing to Audio and Acoustics (WASPAA), pp.394-406, 2015. ,
DOI : 10.1109/TASLP.2014.2372342
A Douglas???Rachford Splitting Approach to Nonsmooth Convex Variational Signal Recovery, IEEE Journal of Selected Topics in Signal Processing, vol.1, issue.4, pp.564-574, 2007. ,
DOI : 10.1109/JSTSP.2007.910264
URL : https://hal.archives-ouvertes.fr/hal-00621820
Signal Recovery by Proximal Forward-Backward Splitting, Multiscale Modeling & Simulation, vol.4, issue.4, pp.1168-1200, 2005. ,
DOI : 10.1137/050626090
URL : https://hal.archives-ouvertes.fr/hal-00017649
Speech Distortion Weighted Multichannel Wiener Filtering Techniques for Noise Reduction, pp.199-228, 2005. ,
DOI : 10.1007/3-540-27489-8_9
Blind multichannel identification and equalization for dereverberation and noise reduction based on convolutive transfer function, 1706. ,
URL : https://hal.archives-ouvertes.fr/hal-01568835
Non-stationary noise power spectral density estimation based on regional statistics, 2016 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.181-185, 2016. ,
DOI : 10.1109/ICASSP.2016.7471661
URL : https://hal.archives-ouvertes.fr/hal-01250892
Erlang Distribution, Statistical Distributions, pp.84-85, 2010. ,
DOI : 10.1002/9780470627242.ch15
Convex analysis, 2015. ,
DOI : 10.1515/9781400873173
Monotone operator splitting for optimization problems in sparse recovery, 2009 16th IEEE International Conference on Image Processing (ICIP), pp.1461-1464, 2009. ,
DOI : 10.1109/ICIP.2009.5414555
URL : https://hal.archives-ouvertes.fr/hal-00813889
Gradient methods for minimizing composite objective function, " tech. rep., International Association for Research and Teaching, 2007. ,
DOI : 10.1007/s10107-012-0629-5
A Fast Iterative Shrinkage-Thresholding Algorithm for Linear Inverse Problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, pp.183-202, 2009. ,
DOI : 10.1137/080716542
Multichannel audio database in various acoustic environments, 2014 14th International Workshop on Acoustic Signal Enhancement (IWAENC), pp.313-317, 2014. ,
DOI : 10.1109/IWAENC.2014.6954309
Getting started with the DARPA TIMIT CD-ROM: An acoustic phonetic continuous speech database, National Institute of Standards and Technology (NIST), vol.107, 1988. ,
On the evaluation of estimated impulse responses, IEEE Signal Processing Letters, vol.5, issue.7, pp.174-176, 1998. ,
DOI : 10.1109/97.700920
Performance measurement in blind audio source separation, IEEE Transactions on Audio, Speech and Language Processing, vol.14, issue.4, pp.1462-1469, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00544230
Perceptual evaluation of speech quality (PESQ)-a new method for speech quality assessment of telephone networks and codecs, 2001 IEEE International Conference on Acoustics, Speech, and Signal Processing. Proceedings (Cat. No.01CH37221), pp.749-752, 2001. ,
DOI : 10.1109/ICASSP.2001.941023
An Integrated Real-Time Beamforming and Postfiltering System for Nonstationary Noise Environments, EURASIP Journal on Advances in Signal Processing, vol.2003, issue.11, pp.1064-1073, 2003. ,
DOI : 10.1155/S1110865703305050
URL : https://doi.org/10.1155/s1110865703305050
Speech Enhancement Based on the General Transfer Function GSC and Postfiltering, IEEE Transactions on Speech and Audio Processing, vol.12, issue.6, pp.561-571, 2004. ,
DOI : 10.1109/TSA.2004.834599
