Qualitative Methods for Heterogeneous Media, 2015. ,
URL : https://hal.archives-ouvertes.fr/tel-01203647
A generalized formulation of the linear sampling method with exact characterization of targets in terms of farfield measurements, Inverse Problems, vol.30, issue.3, p.35011, 2014. ,
DOI : 10.1088/0266-5611/30/3/035011
URL : https://hal.archives-ouvertes.fr/hal-00911692
The Generalized Linear Sampling Method for Limited Aperture Measurements, SIAM Journal on Imaging Sciences, vol.10, issue.2, pp.845-870, 2017. ,
DOI : 10.1137/16M110112X
URL : https://hal.archives-ouvertes.fr/hal-01422027
On the use of Perfectly Matched Layers at corners for scattering problems with sign-changing coefficients, Journal of Computational Physics, vol.322, p.322, 2016. ,
DOI : 10.1016/j.jcp.2016.06.037
URL : https://hal.archives-ouvertes.fr/hal-01225309
Inverse Scattering Theory and Transmission Eigenvalues, CBMS Series, p.2016 ,
DOI : 10.1137/1.9781611974461
Stekloff Eigenvalues in Inverse Scattering, SIAM Journal on Applied Mathematics, vol.76, issue.4, pp.1737-1763, 2016. ,
DOI : 10.1137/16M1058704
On the determination of Dirichlet or transmission eigenvalues from far field data, Comptes Rendus Mathematique, vol.348, issue.7-8, pp.348-379, 2010. ,
DOI : 10.1016/j.crma.2010.02.003
URL : https://hal.archives-ouvertes.fr/hal-00739142
The Existence of an Infinite Discrete Set of Transmission Eigenvalues, SIAM Journal on Mathematical Analysis, vol.42, issue.1, pp.237-255, 2010. ,
DOI : 10.1137/090769338
URL : https://hal.archives-ouvertes.fr/hal-00739145
On the use of transmission eigenvalues to estimate the index of refraction from far field data, Inverse Problems, vol.23, issue.2, pp.507-522, 2007. ,
DOI : 10.1088/0266-5611/23/2/004
Analysis of the factorization method for a general class of boundary conditions. J. Inverse Ill-Posed Probl, pp.643-670, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00783288
Modified transmission eigenvalues in inverse scattering theory, Inverse Problems, vol.33, issue.12 ,
DOI : 10.1088/1361-6420/aa9418
Inverse Acoustic and Electromagnetic Scattering Theory, 2013. ,
DOI : 10.1007/978-3-662-03537-5
Computing estimates of material properties from transmission eigenvalues, Inverse Problems, p.55009, 2012. ,
DOI : 10.1088/0266-5611/28/5/055009
URL : http://hal.inria.fr/docs/00/61/92/32/PDF/RR-7729.pdf
Transmission eigenvalues and non-destructive testing of anisotropic magnetic materials with voids, Inverse Problems, vol.30, issue.3, p.35016, 2014. ,
DOI : 10.1088/0266-5611/30/3/035016
New development in freefem++, Journal of Numerical Mathematics, vol.20, issue.3-4, pp.251-265, 2012. ,
DOI : 10.1515/jnum-2012-0013
URL : https://hal.archives-ouvertes.fr/hal-01476313
Extremum Problems for Eigenvalues of Elliptic Operators, 2000. ,
URL : https://hal.archives-ouvertes.fr/hal-00087731
Grinberg The Factorization Method for Inverse Problems, 2008. ,
DOI : 10.1093/acprof:oso/9780199213535.001.0001
The inside???outside duality for scattering problems by inhomogeneous media, Inverse Problems, vol.29, issue.10, p.104011, 2013. ,
DOI : 10.1088/0266-5611/29/10/104011
A modification of the factorization method for the classical acoustic inverse scattering problems, Inverse Problems, vol.30, issue.3, p.35013, 2014. ,
DOI : 10.1088/0266-5611/30/3/035013
Determining transmission eigenvalues of anisotropic inhomogeneous media from far field data, Communications in Mathematical Sciences, vol.13, issue.7, pp.131803-1827, 2015. ,
DOI : 10.4310/CMS.2015.v13.n7.a8
Geometric Scattering Theory, 1995. ,
Numerical computations of interior transmission eigenvalues for scattering objects with cavities, Inverse Problems, vol.32, issue.4, p.45001, 2016. ,
DOI : 10.1088/0266-5611/32/4/045001
Geometry of the Generalized Geodesic Flow and Inverse Spectral Problems, 2017. ,
DOI : 10.1002/9781119107682
Finite Element Methods for Eigenvalue Problems, 2016. ,
High-Frequency approximation of the interior Dirichlet-to-Neumann mao and applications to the transmission eigenvalues ,
