Qualitative Methods for Heterogeneous Media, 2015. ,
URL : https://hal.archives-ouvertes.fr/tel-01203647
Generalized impedance boundary conditions for thin dielectric coatings with variable thickness, Wave Motion, vol.48, issue.7, pp.681-700, 2011. ,
DOI : 10.1016/j.wavemoti.2011.06.002
The Effect of a Thin Coating on the Scattering of a Time-Harmonic Wave for the Helmholtz Equation, SIAM Journal on Applied Mathematics, vol.56, issue.6, pp.1664-1693, 1996. ,
DOI : 10.1137/S0036139995281822
Haddar Inverse Scattering Theory and Transmission Eigenvalues SIAM publications, 2016. ,
DOI : 10.1137/1.9781611974461
On the determination of dirichlet or transmission eigenvalues from farfield data, C. R. Acad. Sci. paris, issue.78, pp.379-383, 2010. ,
Transmission eigenvalues in inverse scattering theory Inverse Problems and Applications, Inside Out 60, 2013. ,
The Existence of an Infinite Discrete Set of Transmission Eigenvalues, SIAM Journal on Mathematical Analysis, vol.42, issue.1, pp.237-255, 2010. ,
DOI : 10.1137/090769338
URL : https://hal.archives-ouvertes.fr/hal-00739145
Asymptotic expansions for transmission eigenvalues for media with small inhomogeneities, Inverse Problems, vol.29, issue.10, pp.104014-104032, 2013. ,
DOI : 10.1088/0266-5611/29/10/104014
URL : http://www.math.udel.edu/~cakoni/p3.pdf
The Existence of an Infinite Discrete Set of Transmission Eigenvalues, SIAM Journal on Mathematical Analysis, vol.42, issue.1, pp.527-578 ,
Asymptotic analysis of the transmission eigenvalue problem for a Dirichlet obstacle coated by a thin layer of non-absorbing media, IMA Journal of Applied Mathematics, vol.80, issue.4, pp.1063-1098, 2015. ,
DOI : 10.1093/imamat/hxu045
URL : https://hal.archives-ouvertes.fr/hal-01109975
Inverse Acoustic and Eletromagnetic Scattering Theory, 2012. ,
DOI : 10.1007/978-3-662-03537-5
Abstract, Computational Methods in Applied Mathematics, vol.14, issue.4, pp.419-427, 2014. ,
DOI : 10.1515/cmam-2014-0021
Approximate models for wave propagation across thin periodic interfaces, Journal de Math??matiques Pures et Appliqu??es, vol.98, issue.1, pp.28-71, 2012. ,
DOI : 10.1016/j.matpur.2012.01.003
URL : https://hal.archives-ouvertes.fr/hal-00741614
Computing estimates of material properties from transmission eigenvalues, Inverse Problems, vol.28, issue.5, p.55009, 2012. ,
DOI : 10.1088/0266-5611/28/5/055009
URL : https://hal.archives-ouvertes.fr/hal-00743910
Transmission eigenvalues and non-destructive testing of anisotropic magnetic materials with voids, Inverse Problems, vol.30, issue.3, p.35016, 2014. ,
DOI : 10.1088/0266-5611/30/3/035016
The imaging of small perturbations in an anisotropic media, Computers and Mathematics with Applications, to appear, 2017. ,
Extremum Problems for Eigenvalues of Elliptic Operators, 2000. ,
URL : https://hal.archives-ouvertes.fr/hal-00087731
A mixed finite element method for Helmholtz Transmission eigenvalues, ACM Transaction on Math. Soft, vol.38, issue.4, 0922. ,
The inside???outside duality for scattering problems by inhomogeneous media, Inverse Problems, vol.29, issue.10, 2013. ,
DOI : 10.1088/0266-5611/29/10/104011
Nonlinear eigenvalue approximation for compact operators, Journal of Mathematical Physics, vol.56, issue.11, p.113512, 2015. ,
DOI : 10.1137/070697525
URL : http://arxiv.org/pdf/1408.3289
Functional analysis, 1980. ,
Partial Differential Equations, 1987. ,
DOI : 10.1017/CBO9781139171755
Transmission Eigenvalues, SIAM Journal on Mathematical Analysis, vol.40, issue.2, pp.738-753 ,
