Krylov methods applied to reactive transport models - Archive ouverte HAL Access content directly
Conference Papers Year : 2017
(1)
1
Reactive transport models couple advection dispersion equations with chemistry equations. If the reactions are at thermodynamic equilibrium, then the system is a set of partial differential and algebraic equations. After space and implicit time discretizations, a nonlinear system of equations must be solved at each time step. The Jacobian matrix of the nonlinear system can be written with a Kronecker product coupling transport and chemistry. Krylov methods are well-suited to solve such linear systems because the matrix vector product can be done efficiently. The main challenge is to design a preconditioning matrix. We propose here to use the special structure of the matrix. Preliminary experiments show that Krylov methods are much more efficient than a direct method which does not use the coupled structure.
siamgs2017-erhel.pdf (569.25 Ko) Télécharger le fichier
Dates and versions
hal-01646268 , version 1 (23-11-2017)
Identifiers
  • HAL Id : hal-01646268 , version 1
Cite
Jocelyne Erhel. Krylov methods applied to reactive transport models. SIAM Conference on Mathematical and Computational Issues in the Geosciences, Sep 2017, Erlangen, Germany. ⟨hal-01646268⟩
379 View
18 Download
Share
