Conference papers
Research on Association Rules Reasoning and Application of Geosciences Data Based on Ameliorated Trapezoidal Cloud Transformation
Abstract : This paper proposes an association rules reasoning model based on ameliorated trapezoidal cloud transformation. It is aimed primarily at complexity and randomness geosciences data bears. The traditional trapezoidal cloud transformation is improved in order to avoid lack of data mutation information and to finish reasonable and sensitive exchange from qualification to quantification. A set of attributes for simulating faults extraction algorithm is designed, which breaks through limitations of traditional visual interpretation and ensures an effectiveness and completeness of test data. Multi-Level Association Rules (MLAR) model [1] is also adopted to reason and predict unknown faults and fault properties in Chengdu Office zone. The result shows that the MLAR algorithm enhanced an association mining between fault types with their classified attributes.
Complete list of metadata
Cited literature [13 references]  Display  Hide  Download
https://hal.inria.fr/hal-01646551
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Thursday, November 23, 2017 - 3:28:12 PM
Last modification on : Friday, November 24, 2017 - 1:27:53 AM
File
428533_1_En_14_Chapter.pdf
Identifiers
Citation
Xu Jing. Research on Association Rules Reasoning and Application of Geosciences Data Based on Ameliorated Trapezoidal Cloud Transformation. 17th International Conference on Informatics and Semiotics in Organisations (ICISO), Aug 2016, Campinas, Brazil. pp.127-132, ⟨10.1007/978-3-319-42102-5_14⟩. ⟨hal-01646551⟩
Share
Metrics
Record views
62
Files downloads
58
