A Semantically-Based Big Data Processing System Using Hadoop and Map-Reduce - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In financial industry, a wide range of financial systems generate vast amount of data in different structures, which change with compliance rules change and hard to manage due to their heterogeneity. This paper introduces a semantically-based big data processing system to integrate the data from different sources, which realizes the query and computation in semantic layer. The system provides a new data management way for the financial industry. With Semantic Web, the information can be managed, integrated, and collaborated in a more fluent way than it in traditional ETL. In order to clear the complex logical relationship among data, the system uses SPARQL to query. Through Map-Reduce, this system, based on Hadoop and Hbase can improve the processing speed for big data.
BookBackmatter_6.pdf (189.98 Ko) Télécharger le fichier
hal-01646637 , version 1 (23-11-2017)
Paternité
  • HAL Id : hal-01646637 , version 1
Wang Wanting, Qin Zheng. A Semantically-Based Big Data Processing System Using Hadoop and Map-Reduce. 17th International Conference on Informatics and Semiotics in Organisations (ICISO), Aug 2016, Campinas, Brazil. pp.246-247. ⟨hal-01646637⟩
112 Consultations
34 Téléchargements
