New interface
Journal articles
Correctness of Speculative Optimizations with Dynamic Deoptimization
Olivier Flückiger 1 Gabriel Scherer 1, 2 Ming-Ho Yee 1 Aviral Goel 1 Amal Ahmed 1, 3 Jan Vitek 1
2 PARSIFAL - Proof search and reasoning with logic specifications
LIX - Laboratoire d'informatique de l'École polytechnique [Palaiseau], Inria Saclay - Ile de France
Abstract : High-performance dynamic language implementations make heavy use of speculative optimizations to achieve speeds close to statically compiled languages. These optimizations are typically performed by a just-in-time compiler that generates code under a set of assumptions about the state of the program and its environment. In certain cases, a program may execute code compiled under assumptions that are no longer valid. The implementation must then deoptimize the program on-the-fly; this entails finding semantically equivalent code that does not rely on invalid assumptions, translating program state to that expected by the target code, and transferring control. This paper looks at the interaction between optimization and deoptimization, and shows that reasoning about speculation is surprisingly easy when assumptions are made explicit in the program representation. This insight is demonstrated on a compiler intermediate representation, named sourir, modeled after the high-level representation for a dynamic language. Traditional compiler optimizations such as constant folding, unreachable code elimination, and function inlining are shown to be correct in the presence of assumptions. Furthermore, the paper establishes the correctness of compiler transformations specific to deoptimization: namely unrestricted deoptimization, predicate hoisting, and assume composition.
Document type :
Journal articles
Complete list of metadata
Cited literature [23 references]  Display  Hide  Download
https://hal.inria.fr/hal-01646765
Contributor : Scherer Gabriel Connect in order to contact the contributor
Submitted on : Thursday, November 23, 2017 - 5:27:55 PM
Last modification on : Friday, November 18, 2022 - 9:27:47 AM
File
sourir.pdf
Distributed under a Creative Commons Attribution - ShareAlike 4.0 International License
Identifiers
Citation
Olivier Flückiger, Gabriel Scherer, Ming-Ho Yee, Aviral Goel, Amal Ahmed, et al.. Correctness of Speculative Optimizations with Dynamic Deoptimization. Proceedings of the ACM on Programming Languages, 2018, 2 (POPL), ⟨10.1145/3158137⟩. ⟨hal-01646765⟩
Share
Metrics
Record views
622
Files downloads
126
