Reports
Realizability of Schedules by Stochastic Time Petri Nets with Blocking Semantics: (Extended Version)
Loïc Hélouët 1 Karim Kecir 1
1 SUMO - SUpervision of large MOdular and distributed systems
Inria Rennes – Bretagne Atlantique , IRISA-D4 - LANGAGE ET GÉNIE LOGICIEL
Abstract : This paper considers realizability of expected schedules by production systems with concurrent tasks, bounded resources that have to be shared among tasks, and random behaviors and durations. Schedules are high level views of desired executions of systems represented as partial orders decorated with timing con- straints. Production systems (production cells,train networks. . . ) are modeled as stochastic time Petri nets STPNs with an elementary (1-bounded) semantics. We detail their interleaved operational semantics, and then propose a non-interleaved semantics through the notion of time processes. We then consider boolean re- alizability: a schedule S is realizable by a net N if S embeds in a time process of N that satisfies all its constraints. However, with continuous time domains, the probability of a time process with exact dates is null. We hence consider probabilistic realizability up to α time units, that holds if the probability that N realizes S with constraints enlarged by α is strictly positive. Upon a sensible restriction guaranteeing time progress, boolean and probabilistic realizability of a schedule can be checked on the finite set of symbolic prefixes extracted from a bounded unfolding of the net. We give a construction technique for these prefixes and show that they represent all time processes of a net occurring up to a given maximal date. We then show how to verify existence of an embedding and compute the probability of its realization.
Complete list of metadata
Cited literature [34 references]  Display  Hide  Download
https://hal.inria.fr/hal-01646920
Contributor : Loic Helouet Connect in order to contact the contributor
Submitted on : Monday, November 27, 2017 - 3:11:37 PM
Last modification on : Monday, April 4, 2022 - 9:28:22 AM
File
SCP-LHKK-Revision1.pdf
Identifiers
  • HAL Id : hal-01646920, version 2
Citation
Loïc Hélouët, Karim Kecir. Realizability of Schedules by Stochastic Time Petri Nets with Blocking Semantics: (Extended Version). [Research Report] INRIA Rennes - Bretagne Atlantique. 2017. ⟨hal-01646920v2⟩
Share
Metrics
Record views
458
Files downloads
192
